Very simple quasi complimentary MOSFET amplifier
It just depends on how much power supply ripple you are willing to tolerate. At some point, it has audible hum from the mains. 4 x 4700uF should be fine for many Class AB amps (as a speaker amp). I myself, just ordered 8 x 9600uF 50v caps from Mouser and they cost a pretty penny - the single biggest cost of this amp, aside from the CNC aluminum case.
Yes, thanks X, 42V
My future VSQ will be similar to post #1658, as my avaiable transformers will give supply about +-48Vdc. 😱
After a small trip to Portugal... 😎
Attached the single channel supplies.
Regards.
Unfortunately I had a little mishap.😱I pulled the connector out of the signal generator while the amp were still powered. I suppose it caused a feedback or oscillation that killed both output devices on one module. Will have to source trannies for that. I found that the output is 100% with a square wave on 1khz but on 10khz there is a little overshoot and a notch. Any idea how to fix that ?
I was also wondering about the schematic to this layout. Especial the power-section, one input and three rectifiers at each side ?
Can anyone please point me to the schematic?
And regarding the power supply for this application and in general. What about using a DC-DC converter instead of capacitance multiplier? Cheaper better?
Lydlaug
Lydlaug
Yes, this circuit has a few departures from the basic quasi circuit we have all used up to this point from Christian and Hugh. I have never seen 3 diodes on a rectifier before. It would be good to have the final schematic corresponding to the board - I can't seem to find it either and I have the board in hand.
I have received the new MJL3281trannies. They do look a little different from my old one's. But they work well , got them from RS so should be original. Both channels running at +- 34mv bias and sounds superbb ! This would be be finished before x-mas for my daughter !! Thanks Hugh, Ranchu and all !!😀😀😀😀
the rectification was suggested by Hugh, identical to the Aspen Fetzilla.
