I haven't been able to find a 6JC6 pentode model for LTspice. Is there one?
smoking_amp posted some 6JC6 triode curves he traced
(2 mA/div Vert., 50 V/div. Horiz., grid in -0.5 V steps):
https://www.diyaudio.com/forums/att...power-amp-design-rsz_6jc6_t_05vs_20ma_50v-jpg
6JC6 data sheet:
https://frank.pocnet.net/sheets/049/6/6JC6.pdf
Is that enough info? (I hope so...)
I have a 6JC6 triode model I could post, if anybody's interested. I don't remember where I found it...
6JC6 data sheet:
KT66 triode model
Hi there, is there any reliable ltspice model for the KT66 in triode mode ?
Thanks all in advance.
Danilo
Danilo
I found spice model of 1П24Б russian submini tube but I also need 1Ж18Б and 1Ж24Б both pentode. Anybody can help ?
http://www.etd.su/short/202/1/1z18b.GIF
http://www.etd.su/short/202/1/1z24b.GIF
Looking for directly heated triode 5A6 Ltspice model
Dear All,
I have searched the forum in vain for 5A6 ltspice model. Is it possible to generate one based on the following data?
Datasheet with pentode loadlines, interelectrodes capacitance:
http://rtellason.com/tubedata/5A6.pdf
http://tubedata.jp/sheets/020/5/5A6.pdf
A Gentleman from Japan has made a triode strapped 5a6 loadlines:
5A6三結実測値からLTSPICEモデルの作成 ( オーディオ )
Any pentode or triode model are welcome.
Many thanks in advance.😀
Attached pictures are from the Japanese gentleman's website.
Dear All,
5A6 SPICE Models
Since the models are derived from a single traced sample, please do not expect high accuracy.
Triode-Connected Model
Pentode Model
Code:
* Generic triode model: 5A6_T_AN
* Copyright 2003--2008 by Ayumi Nakabayashi, All rights reserved.
* Version 3.10, Generated on Tue Oct 02 10:49:05 2018
* Anode
* | Grid
* | | Cathode
.SUBCKT 5A6_T_AN A G K
BGG GG 0 V=V(G,K)+0.99998753
BM1 M1 0 V=(0.015698277*(URAMP(V(A,K))+1e-10))**-0.15008063
BM2 M2 0 V=(0.90904648*(URAMP(V(GG)+URAMP(V(A,K))/5.7938533)+1e-10))**1.6500806
BP P 0 V=0.00061411819*(URAMP(V(GG)+URAMP(V(A,K))/6.3735501)+1e-10)**1.5
BIK IK 0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.00043471673*V(M1)*V(M2)
BIG IG 0 V=0.00030705909*URAMP(V(G,K))**1.5*(URAMP(V(G,K))/(URAMP(V(A,K))+URAMP(V(G,K)))*1.2+0.4)
BIAK A K I=URAMP(V(IK,IG)-URAMP(V(IK,IG)-(0.00045711939*URAMP(V(A,K))**1.5)))+1e-10*V(A,K)
BIGK G K I=V(IG)
* CAPS
CGA G A 0.15p
CGK G K 8.5p
CAK A K 5.8p
.ENDS
Pentode Model
Code:
* Generic pentode model: 5A6_AN
* Version 3.10, Generated on Tue Oct 02 10:49:25 2018
* Anode
* | Screen Grid
* | | Control Grid
* | | | Cathode
.SUBCKT 5A6_AN A G2 G1 K
BGG GG 0 V=V(G1,K)+0.99998753
BM1 M1 0 V=(0.015698277*(URAMP(V(G2,K))+1e-10))**-0.15008063
BM2 M2 0 V=(0.90904648*(URAMP(V(GG)+URAMP(V(G2,K))/5.7938533)))**1.6500806
BP P 0 V=0.00061411819*(URAMP(V(GG)+URAMP(V(G2,K))/6.3735501))**1.5
BIG IG 0 V=0.00030705909*URAMP(V(G1,K))**1.5*(URAMP(V(G1,K))/(URAMP(V(A,K))+URAMP(V(G1,K)))*1.2+0.4)
BIK2 IK2 0 V=V(IK,IG)*(1-0.4*(EXP(-URAMP(V(A,K))/URAMP(V(G2,K))*15)-EXP(-15)))
BIG2T IG2T 0 V=V(IK2)*(0.86457278*(1-URAMP(V(A,K))/(URAMP(V(A,K))+10))**1.5+0.13542722)
BIK3 IK3 0 V=V(IK2)*(URAMP(V(A,K))+5850)/(URAMP(V(G2,K))+5850)
BIK4 IK4 0 V=V(IK3)-URAMP(V(IK3)-(0.00045711939*(URAMP(V(A,K))+URAMP(URAMP(V(G2,K))-URAMP(V(A,K))))**1.5))
BIP IP 0 V=URAMP(V(IK4,IG2T)-URAMP(V(IK4,IG2T)-(0.00045711939*URAMP(V(A,K))**1.5)))
BIAK A K I=V(IP)+1e-10*V(A,K)
BIG2 G2 K I=URAMP(V(IK4,IP))
BIGK G1 K I=V(IG)
* CAPS
CGA G1 A 0.15p
CGK G1 K 5.1p
C12 G1 G2 3.4p
CAK A K 5.8p
.ENDS
It seems that nobody has one...
So, let me rephrase my question:
Can somebody create one using the curves from the data sheets ?
If you can provide the triode-connected curves, I can try to create a model for the 2E22, otherwise, no luck...
Unfortunately, the traced triode curves did not converge, so please try a different range for Vg, say 0V to -20V in -2V steps. Alternatively, since you have the uTracer, you can follow Dr. Reefman's instruction and generate the SPICE models directly.
2E22 SPICE Model
With a bit of tweaking, I managed to create the pentode model for the 2E22:
Code:
* Generic pentode model: 2E22_AN
* Version 3.10, Generated on Tue Oct 09 11:41:44 2018
* Anode
* | Screen Grid
* | | Control Grid
* | | | Cathode
.SUBCKT 2E22_AN A G2 G1 K
BGG GG 0 V=V(G1,K)+0.95592604
BM1 M1 0 V=(0.027028997*(URAMP(V(G2,K))+1e-10))**-0.35800022
BM2 M2 0 V=(0.80731961*(URAMP(V(GG)+URAMP(V(G2,K))/7.1286551)))**1.8580002
BP P 0 V=0.00093171905*(URAMP(V(GG)+URAMP(V(G2,K))/8.8300285))**1.5
BIK IK 0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.00055787177*V(M1)*V(M2)
BIG IG 0 V=0.00046585952*URAMP(V(G1,K))**1.5*(URAMP(V(G1,K))/(URAMP(V(A,K))+URAMP(V(G1,K)))*1.2+0.4)
BIG2T IG2T 0 V=V(IK2)*(0.924621412*(1-URAMP(V(A,K))/(URAMP(V(A,K))+10))**1.5+0.075378588)
BIK3 IK3 0 V=V(IK2)*(URAMP(V(A,K))+9110)/(URAMP(V(G2,K))+9110)
BIK4 IK4 0 V=V(IK3)-URAMP(V(IK3)-(0.00062853518*(URAMP(V(A,K))+URAMP(URAMP(V(G2,K))-URAMP(V(A,K))))**1.5))
BIP IP 0 V=URAMP(V(IK4,IG2T)-URAMP(V(IK4,IG2T)-(0.00062853518*URAMP(V(A,K))**1.5)))
BIGK G1 K I=V(IG)
* CAPS
CGA G1 A 0.2p
CGK G1 K 9p
C12 G1 G2 6p
CAK A K 8p
.ENDS
Hi, is there any reliable LTSpice 300B model with heater ? and the related DHT symbol.
Danilo
Danilo
Here is a link to 300b with heater model: http://duncanamps.com/spice/valves/dmtriodep.inc
Triode with heater symbol: http://duncanamps.com/spice/valves/triodeh.asy as found in LTSpice and vacuum tube models
Look in the directory for files mentioned above here: Index of /spice/valves
So, is there a tutorial somewhere that tells me how to generate Spice models? I hate to keep troubling the rest of you! At the moment I am awaiting delivery of a nearly 100 year old radio that I would like to restore to operation. It uses ancient tubes (triodes only) that are likely to be of little interest to anyone here. I take it that some of you use a digital curve tracer of one kind or another. In fact I see the uTracer mentioned not far above and from looking at their website I get some information. At the moment it is too expensive for my purposes. That perception could change if I do too much more tube work but for now I would need a cheaper hardware option, if there are any, or is it possible to generate the models from datasheet curves?
- Tubes / Valves
- Vacuum Tube SPICE Models
