Vacuum Tube SPICE Models
Proposed 6P9P model is good for me. Quick check tells:
230V/-6V/44mA, and
145V/-1,8V/20mA.
Jazbo, typo is in "info part" of first line. Should be ..... P K G2 G.
But this typo does not affect the directive.
I must have changed the symbol names by mistake, because the model did not work for me as is... let me check it out and get back to you.
This is a circuit where I quickly tested model from post 592.
Symbol model is tetrode model from Misc folder and LT spice.
Thanks, I finally got the model to work but I am getting the same results as artosalo... Did you use the same curve data as shown in the picture below?
1. Ua = 102 V, Ug1 = 0 : Ia = 40 mA
2. Ua = 171 V, Ug1 = -3 : Ia = 38 mA
3. Ua = 242 V, Ug1 = -6 : Ia = 38 mA
So my results show too low anode currents.
6P9 Triode-Connected vs. the datasheet:
Ayumi models always assign the pin numbers from the top to the botton of the tube, e.g., GU50PP A S G K. So just make sure whichever symbol that you use, assigns the pins in the same order. But this particular model was originally intended for TINA, so I don't think it would work in LTSpice at all... try this one instead:
Code:
* Generic pentode model: GU50_AN
* Copyright 2003--2008 by Ayumi Nakabayashi, All rights reserved.
* Version 3.10, Generated on Sat Jan 11 08:13:44 2014
*               Plate
*               | Screen Grid
*               | |  Control Grid
*               | |  |  Cathode
.SUBCKT GU50_AN A G2 G1 K
BGG   GG   0 V=V(G1,K)+0.45288699
BM1   M1   0 V=(0.10715305*(URAMP(V(G2,K))+1e-10))^-1.1401545
BM2   M2   0 V=(0.56814856*(URAMP(V(GG)+URAMP(V(G2,K))/4.0302301)))^2.6401545
BP    P    0 V=0.0015719333*(URAMP(V(GG)+URAMP(V(G2,K))/7.0936201))^1.5
BIK   IK   0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.0011497682*V(M1)*V(M2)
BIG   IG   0 V=0.00078596663*URAMP(V(G1,K))^1.5*(URAMP(V(G1,K))/(URAMP(V(A,K))+URAMP(V(G1,K)))*1.2+0.4)
BIK2  IK2  0 V=V(IK,IG)*(1-0.4*(EXP(-URAMP(V(A,K))/URAMP(V(G2,K))*15)-EXP(-15)))
BIG2T IG2T 0 V=V(IK2)*(0.916000233*(1-URAMP(V(A,K))/(URAMP(V(A,K))+10))^1.5+0.083999767)
BIK3  IK3  0 V=V(IK2)*(URAMP(V(A,K))+2101.25)/(URAMP(V(G2,K))+2101.25)
BIK4  IK4  0 V=V(IK3)-URAMP(V(IK3)-(0.0011298169*(URAMP(V(A,K))+URAMP(URAMP(V(G2,K))-URAMP(V(A,K))))^1.5))
BIP   IP   0 V=URAMP(V(IK4,IG2T)-URAMP(V(IK4,IG2T)-(0.0011298169*URAMP(V(A,K))^1.5)))
BIAK  A    K I=V(IP)+1e-10*V(A,K)
BIG2  G2   K I=URAMP(V(IK4,IP))
BIGK  G1   K I=V(IG)
* CAPS
CGA   G1  A  0.1p
CGK   G1  K  8.4p
C12   G1  G2 5.6p
CAK   A   K  9.2p
.ENDS
Hi everyone,
I'm trying to do a simulation of Bassman 5F6-A (1959) in PSpice. How can I simulate the output transformer? Use magnetic.lib from spice or create a new model? I don't know nothing about the core...
You can modify the values to suit the 5F6-A's OPT:
Code:
.SUBCKT PP_OUTPUT_XFRMR 1 2 3 4 5
* PUSH PULL OUTPUT XFRMR
* 5000 OHM PRIMARY
* 8 OHM SECONDARY
* 100H TOTAL PRIMARY INDUCANCE
LP1	1	21	50	;Henries
RP1	21	2	70	;ohms
RP2	2	23	70	;ohms
LP2	23	3	50	;Henries
LS1	4	5	0.16	;Henries
CP1 1 3   2NF     ; CAPACITANCE
KALL LP1 LP2 LS1 .9999875
.ENDS
GU-50:
I am using next model:
.SUBCKT GU50 1 2 3 4 ; P G1 C G2 (Pentode) 21-Nov-2001
+ PARAMS: MU=8.5 EX=1.350 KG1=800 KP=15.9 KC=8000
+ KVB=30.3 VCT=0.00 RGI=1k
+ CCG=14P CPG1=0.4P CCP=9.2P
RE1 7 0 1G
RE2 8 3 1G
E1 7 0 VALUE= ; E1 BREAKS UP LONG EQUATION FOR G1.
+{V(4,3)/KP*LOG(1+EXP((1/MU+V(2,3)/V(4,3))*KP))}
G1 1 3 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1*ATAN(V(1,3)/KVB)}
G2 8 3 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KC*(2.5708-ATAN(V(1,3)/KVB))}
E2 8 4 VALUE={0}
RCP 1 3 1G ;
C1 2 3 {CCG} ;
C2 1 2 {CPG1} ;
C3 1 3 {CCP} ;
R1 2 5 {RGI} ;
D3 5 3 DX ;
.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N)
.ENDS
and Tetrode-RY symbol
Good model Matej. I think that is based on the LS50 curves.
When used tetrode symbol from Misc folder in LT spice, first line should be:
.SUBCKT GU50 1 4 2 3; (Pentode) 21-Nov-2001
That works for me.
