22 ohms in supply rails caused the clipping problem. So I left them, now everything seems right. I think it will be good already, I'm going to design the PCB. Minek, did you simulate Gain and Phase margin?
this open loop gain sim
1u extreme!!!@Maxim. Since the missing parts are already on way from mouser, I would like to finalize the circuit of qhex version and I'm going to design the PCB. The amplifier shows ugly clipping characteristics when R1 = 33 Ohms are used. It looks much better with 100 Ohms (In original Wiederhold it is 1k). What do you think? Also, since I don’t have enough knowledge in LTSpice, could anyone simulate the Phase and Gain margin of the circuit? Currently I only have +/-33V Power Supply. This is why I set the simulation to 33V. Thank you for the help.
First image 10kHz square wave on 6Ohm, the second one is same, but with 1u capacitor parallel with load.
1uF is way too much...
Thank you!
6 Ohm+100nF
Stability of an amplifier under capacitive loading
Try with 10n to 20n, that's way more reasonable...
Decent. Just a slight difference compared to resistive load.
can you attach your asc file with square AC source?
Something is wrong with cascaded driver. Using single transistor to drive VAS everything seems to be OK (original version). Even on 2 Ohms.
This is Lomakin/Parshin amp.
Different than Wiederhold (compensation), and this is not quasi...
Can't really be compared
Change R5 to 1k2 in your wiederhold1977_qhex-3_egra_sqw.asc
and retry 4 ohm
I mentioned this R5 change in one the previous posts...
and retry 4 ohm
and retry 4 ohm
Thank you. Perfect now.
I removed some stuff added, and restored original values, at 45V rails, with R5=910, and square at 4 Ohm look ok to me, even at 1.2V AC input (instead of 0.7)
Either C9/C12 should stay at 120pF (this value depends on output fets, for IRFPs might be different), or removal of diodes in the rails helped...
- Unusual amp from 1987
