Unusual amp from 1987
First image 10kHz square wave on 6Ohm, the second one is same, but with 1u capacitor parallel with load.
@Maxim. Since the missing parts are already on way from mouser, I would like to finalize the circuit of qhex version and I'm going to design the PCB. The amplifier shows ugly clipping characteristics when R1 = 33 Ohms are used. It looks much better with 100 Ohms (In original Wiederhold it is 1k). What do you think? Also, since I don’t have enough knowledge in LTSpice, could anyone simulate the Phase and Gain margin of the circuit? Currently I only have +/-33V Power Supply. This is why I set the simulation to 33V. Thank you for the help.
1u extreme!!!
Joined 2014
I removed some stuff added, and restored original values, at 45V rails, with R5=910, and square at 4 Ohm look ok to me, even at 1.2V AC input (instead of 0.7)
Either C9/C12 should stay at 120pF (this value depends on output fets, for IRFPs might be different), or removal of diodes in the rails helped...
  • wiederhold1977_qhex_sqw.asc
