I started with minimal bias (Idle_Pot set to max: 520 Ohm).
Voltage between driver's bases is 8.4V
At normal bias (40mV idle current) it's supposed to be 1V - 2V higher than that.
Now I'm trying the same in the sim (low bias), and it looks like with minimal bias (Idle_Pot 520 Ohm) - it is oscillating in LT Spice.
I'm assuming this - as the ltspice takes forever to finish simulation (been running for 5 min already), which usually means that something bad is happening.
Will play a little with sim, and I guess with try with higher/normal bias. Obviously, it sims OK with normal bias.
So far I've been testing without input, and without output load.
Or, do you think it's better to start with C7/R20 changes instead of higher bias?
Update: Well, changing bias is easier, so will try this first.
If you increase the capacity of c10, you can catch trouble. the resistor is better to start with 5-10.Or, do you think it's better to start with C7/R20 changes instead of higher bias?
With higher bias is oscillating/behaving the same way. So that's not the issue.
So now looking at R20, C7, C10, C2, C8.
When you say "Turn off the limiter diodes temporarily" you mean
something like "remove R4" ?
The sim doesn't work with R4 removed completely.
I guess you mean removed diodes only.
R4/C7 is needed for compensation.
But I think D3/D4 shouldn't matter too much, they just add several pF of capacity to C7, that's all (as far as problem of oscillations goes).
So this amp has 3 RC compensation networks:
C2/R30, R4/C7, R9/C8
and possibly 4th one: R20/C10
With R20 at 10 Ohm - still oscillating, sagging negative rail, stuck to -9V.
With R20 at 18 Ohm - no oscillations, but Q5 looks like is not conducting, so as a result, voltage on lower driver base is -43V and on upper driver base: -34V,
and output also at -34V or so..
So next thing to try should be removal of diodes?
When I look at the current through R4 and D4 (in the sim), it has ugly spikes...
With R20=18 Ohm, Voltage on Q5 collector(and Q7 base) is -34V. That's not right.
It supposed to be over +4V.
R20 back at 3 Ohm (actual resistor 3.4 Ohm).
Limiter diodes removed, but still oscillating the same way. No difference.
Negative rail stuck at -9V.
Highly unlikely, but of course possible.
Will check everything.
Вряд ли, но, конечно, возможно. Все проверю.
Question - this is 1st time I'm testing amp with NFB returning to the input signal (op-amp (+) pin).
R1 + R26 (resistors at the input) will determine the gain.
Shouldn't I connect input to the ground when testing?
If nothing is connected to the input of the amp, what's gonna happen to the gain??
If R1+R26 as not grounded by the input signal (pre-amp) the gain will be 0 ?
I wonder why we don't see this solution more often, in other amps? It allows to save on one big, bipolar capacitor
usually connected from NFB to the ground via R, so it should be used more widely.
Perhaps this solution has some other shortcomings?
>Replace the 200pf capacitor with a Panasonic 100-200uf bipolar and everything will be OK.
Did you try smaller values?
- Unusual amp from 1987
