to GOD be all the glory. my latest project based on this forum. i read notes on ir class d layout and there has been an improvement on noise issues . this is more silent than my previous designs .
works well but care has to be taken when soldering smd parts . some are too close to each other, maybe some day i will order a pre soldered board 😎
have fun all
gtG ucd 1100 rev 1.0 with protect semi smd part list.pdf44.2 KB · Views: 465
gtG ucd 1100 rev 1.0 with protect semi smd pcb bottom.pdf37.9 KB · Views: 487
gtG ucd 1100 rev 1.0 with protect semi smd components 2.pdf234.8 KB · Views: 625
gtG ucd 1100 rev 1.0 with protect semi smd schematic.pdf45.8 KB · Views: 915
Hello fellow DIY'er,
I would like to ask I have IRFP250n from Harris semicondutor.. what the value of gate resistor I'm going to use.. I will use it in my IRS900
Use 33R Or 39R resistor (fsw=300~350KHz)
Use 47R for 200~250KHz fsw
MANOJ
Please contact with me
Hi Mr.Thien
I am Minh, i want to contact with you as my email:
minh.np2007@gmail.com.
Please send me email if possible. Thanks you so much
Minh.
And PDF file ....
regards 🙂
Hi Mr.Thien
Minh.
works well but care has to be taken when soldering smd parts . some are too close to each other, maybe some day i will order a pre soldered board 😎have fun all
You design a version in tht ? Or equivalent smd transistors ?
What needs to change for transistors irfp250n ?
Hi all
my new AUD600 Rev. 1.2 with limiter using NJM2761. Very simple circuit.
regards
manoj
could you please share yourown circuit for the NJM2761,THS!
Hello everyone .
I would realize irs1500d , but I saw that someone had problems with this project.
I know that the issue should be on the level shifter .
If I replace the input part with AUD600 of manojtm, the amp works?
22uh
Sent from my HTC Desire 516 dual sim using Tapatalk
hi all my ucd class d . i powered mids at +/-75vlts and subs at +/-85vlts outputs irfb4227 . i used two half bridge smps gdt, irfp 460
gtG ucd 1100 rev 3.1 with protect components smd confirm .pdf48.4 KB · Views: 559
thank you for sharing
it is so good
can you redrawe in one layer pcb?
my new version i use smd and a bit small compact board . the ground and -ve planes are also modified and well placed according to ir documents on class d grounding and shielding . will post results and photos soon . stewin
used the sub channel @ 2ohms( four 8ohms 18" subs) and it warmed after pushing it hard for two hours. the mid channel I used 4ohms .and all was well .
- Class D
- UCD 25 watts to 1200 watts using 2 mosfets
