irs 3000
Hi
Thanks friend
Do you have top layer and part list?
Please share to all what all you have.
Hello mates, which of the following amplifiers have better definition audio and efficiency.
The configuration comprising the (IR2110 + CD4049) or (74AC00D + IR2110).
I appreciate all your opinions
Greetings ...
Greetings ...
H i Vohonghai
greetings why have you put .01 cap instead of .01 ohms current sensing
resistor irs 3000 is 2 pair amp
warm regards
andrew lebon
warm regards
andrew lebon
thanksirs 3000
are you have part list for it?
i mean resistor with ?%
it is important to me
how many volts for supply?
can work with + - 35?
can i use in 2 ohm?
Andrewlebon,
do u have the password of manoj's design...i downloaded it a month ago but dint ask for password.....can u provide it to me????
hi i will make the amp i am interested for the one with irfp250 +/-80vlts switching at 250KHzHi stewin,
with limitter or without limitter which one you ask and PCB not compleated
REGARDS
MANOJ
HELLO
Hi andrewlebon beauty. Now next step is to test IR2110 totem with BD139, 140
03 pairs IRFP260N.
Nano.
Hi Nano
greetings
it working with 3 pairs FETS
warm regards
andrew lebon
03 pairs IRFP260N.
Nano.
Hi Nano
greetings
warm regards
andrew lebon
Class D Amp
Class d amp with 4422+2092 and with totem pole
thank you sir,Hi sweet,
My pass: diyaud5new
regards
manoj
and is the pcb ready and fully tested with shortcircuit protection
GOOD MORNING! my dear I really like this amp that you postor only to see that there's nothing you like more mandar detalhado.eu ja tetei can not ride because he had more mistakes I thank you very
03 pairs IRFP260N.
Nano.
Hi Nano
greetingsit working with 3 pairs FETS
warm regards
andrew lebon
works very well with totem, is used in commercial circuits.
hugs.Nano
D
Deleted member 148505
1500WATTS COM 85-0-85V 2RHow many watts of output power does a pair of IRFP260N can handle?
FAIRCHILD IC
Try FAN7392 instead of IR2110 ic seems sound is more refined
warm regards
andrew lebon
warm regards
andrew lebon
- Class D
- UCD 25 watts to 1200 watts using 2 mosfets
