Trust, the most delicious Dx Amplifier
Diy heatsinks
In three steps you can make yours.
-1 find a pizza pot...old or new.
-2 trace lines and cut it the way shown.
-3 bend it as shown i image three.
ready to go!
Carlos
wahaha, uncle, I'm planning to reconstruction the amplifier (well.... alot of problem) so there is some question about the circuitry.
What is the usage of C16 and C17, which is 680pF ? It seems serve no purpose.
About the heatsink, i seems to find something interesting, alot of steel, but seems not thermal conductive enough (high thermal resistant)
It is the fluorescent lamp ballast casing, i have alot of them (just replace them, almost throw it away) They are long square hallow tube, after emptied them, it seems i can cut them into piece and use with stacking. like http://image.made-in-china.com/2f0j00cBvtqYRkgWbV/Fluorescent-Lamp-Bracket.jpg
But they have a layer of paint on outside, which low thermal conductivity i think.
Carlos,
What is the purpose of R18, that connects the output from the speaker terminal (i.e. after the dc blocking condensor) to the bottom of the feedback shunt capacitor ? - is this to alleviate turn-on and turn-off transients whilst the output and feedback condenser are charging up ?
Why is the bottom of the feedback shunt capacitor connected to the input -?
It is a feedback, but i cannot remember
This changes damping, is a voltage divider considering speaker and that resistor, but i cannot remember... three year is to much time to my memory.
I knew..but i do not remember the reason why.
I hope someone remember.
Have you readed the entire thread?.... i do think i have explained that..before it was deleted from my mind.
Try to simulate it to discover the effect,... with and without it..use complex load as a speaker instead of a resistor as speaker...i have no more simulator files of this amplifier.
regards,
Carlos
I see, i often use frame ground... in special to home prototypes
It is alike a picture frame...the wooden surrounding of a picture, the frame.
I do think star ground is better, but not that easy to make the pcboard using star ground...using frame is easier..when you need ground then you have in waiting for you in the neighborhood..the resistance is so small that ground loops will not be a problem..my copper tracks are filled with solder... resistance is 0.001 ohm or less.
Well...there are guys that says this is enough to oscillate...i am not having the oscillation these guys said i would have.
regards,
Carlos
I also want one....
Hi, I need a small single supply amp and after searching the forums I decided on DX-Trust. Thie is my first amp project, so I'd like to make it simple.
It's now under construction, I modified the board layout to fit for my heatsink and available parts and also turned the bias servo (vbe) upside down so it now has a pnp transistor (bd140). The outputs 2sa1941 and 2sc5198 are good for a 70w amplifier according to Toshiba. As output caps I will use four times 2200uF/35V, totally 8800uF, that should be sufficient. Otherwise it will follow the original schematics.
Well, its time to start soldering the parts into place.....🙂
Hi
can I use this amp with this transistor for 2 ohm speakers ?
thanks
I don't think so.... better not to use
It will not be damaged..but sound will not be good...was not made to be used this way.... was not designed to produce high power.
Was conceived to produce a sound "vintage style"...not to produce power...was conceived to use sensitive speakers... full range speakers.
Check the thread ( i cannot remember)... i suppose it was not suggested to be used with 2 ohms loads...maybe 4 ohms.
regards,
Carlos
Thank you very much for comments and encouragements.
My build is progressing rather slowly (as dyi projects should do) and I am still hunting for parts.
But half of the parts are already in, the transistors will be next after I have figured out how to match them without a hfe-meter. I wonder if a simple setup like this:
Successfully choose complementary bipolar transistors | EDN
or this:
Transistor matching
will do the trick?
About the PCB's, they are made using the toner transfer method. I did a lot of experimentation and had a hard time finding the right paper type. So far I had the best luck with thin glossy advertising paper. Double sided PCB's are challenging since the alignment is difficult and the whole arrangement moves and changes shape during the ironing. I ruined one board and must have re-ironed the patterns at least fifteen times before getting it right!
I choose to make the PCB's double sided as an exercise and also to get better current flows to the output transistors. I made a few mistakes in the layout, mostly caused my designing the boards before having the actual parts at hand. Good to know until next time...
Next step is to design the power supply board but that should be relatively easy.
More to come, I will keep you informed as the build progresses.....🙂
Wow. That is a very nice double side diy PCB!!! You made it smaller:superman: it looks AWSOME! Hats off to your work 😉
