Which he is about to go enjoy. Wet dreams to all of you who don't have this luxury when living on the 2nd floor.I present Cal's A/C unit.
Truly a multi function "water craft".I present Cal's A/C unit.
Is that why Lake Mead is empty?The local beer&chips market had a garden hose running to the side of the building.
Indeed, both of my AC's were happily "sloshing" the water around due to the humidity here.The local beer&chips market had a garden hose running to the side of the building.
It was feeding a lawn sprinkler tipped to wet the bottom of the commercial air conditioner condenser coil. Which you should not have to do, on a new properly-sized A/C.
A fan may be able to help spread the cooling in some areas, even a small fan helps.My A/C is running full tilt and has been for days. I have 25°C in here. The hallway is 29°C so there's only so much a single A/C unit can do.
Where's the speaker? Oh, it's inside the inflated part! Clever guy.I present Cal's A/C unit.
The building hallway is 29°C which means the concrete is 29°C... My entire place is 25°C... The fan in this A/C is plenty to mix the air in here compared to the old set up using two 8000 BTU window shakersA fan may be able to help spread the cooling in some areas, even a small fan helps.
