How about the 2SK182ES version? I purchased some recently because THF51 was no longer available from reputable sellers.
why not .... I'll try all tricks known to regular Greedy Boy to make it sing, both THF and 2SK182
except if Papa don't chime in , giving his recipe ....... though - even he's having zillion of them , I'm not sure did he already put them on the bench properly, considering number of projects he's working on
Here's some data on 2SK182 vs THF51S operated Common Source and
Common Drain, biased by a constant current source.
Thanks Mr. Pass
CD biased by a CCS graphs show much less distortion.
Could be interesting a try with big inductor load..
that's cheating ...... same numbers as I got
more important details , Pa?
rail, Iq , Uds?
I did some polishing work today with THF51, not yet finished .....
PSU capacitors price rises up exponentially with voltages from 63V to 100V and +
https://www.mouser.fr/Passive-Compo...4attZ1yx4atu&Rl=75hqwZer3vZ1z0wo8cZ1z0wqf2SGT
that's normal ...... laws of market
and, not because of tech. reasons ...... they've just heard of Singing Bush , thus anticipated increased demand for caps
Bigger cap's for similar price if screw terminal type Aluminum Electrolytic Capacitors - Screw Terminal | Mouser
It's 60V x 3.2A per channel, so it's 192W shared by two devices, unless you are blasting your speakers at maximum power full time.🙂
My THF-51S amps are definitely cool and cold weather amps - not for summer enjoyment.
I was thinking at higher power output, energy is dissipated by the speakers and less dissipation by the transistors.
It's already very hot here... 30vdc 3a.
Need gigantic heatsink for it. And warm up the room even
to Michael Rothacher
Hello Mr. Rothacher,
you know that ZM has the opinion, that sleep is overrated!?🙄
Perhaps 'mother nature' has rocked ZM to a comatose nap?
I am joking.... 😀
Greets
Dirk
I am joking.... 😀
Greets
Dirk
Oh Boy ...... ZM really trying to be systematic ..... twiddle deeeeee
OK , I tried what I could , some refinement both for THF51S and 2SK182ES , to squeeze what I can and know , in Singing Bush format
objectives and goals:
- do not alter schematic , just values and settings
-do not resort to higher voltages , keeping demands for caps at 75-80V bay
-both lowest THD and dominant 2nd, as must
so , what I did , in general :
THF51S - tested one proper pair (matched solely by Ugs) , to confirm similar behavior ; after that tested two more specimens furthest away bu Ugs , being on my disposal
2SK182ES - two of them tested- lowest Ugs and highest Ugs specimens I have
will break posts - one battery of test per post
manage if you can ......
THF51S , Ser. 1Z0081 , first from matched pair, 8R load
Rail 65Vdc
Iq 2A3
output node 37Vdc
Mu resistor string 6 x 0R1
output taken 02R from bottom
this one , Ugs -3V21
Rail 65Vdc
Iq 2A3
output node 37Vdc
THF51S , Ser. 1Z0081 , first from matched pair, 4R load
same conditions
again , this one , Ugs -3V21
same conditions
THF51S , Ser. 1Z0115 , second from matched pair, 8R load
same condition
this one , Ugs -3V22
same condition
THF51S , Ser. 1Z0115 , second from matched pair, 4R load
same condition
again, this one , Ugs -3V22
same condition
- The Singing Bush
