The F6 Revisited
if you look at schematic, 3 repeaters are connected primary to primary, secondary to secondary, obeying phases
so, how you gonna connect it/them in circuit, that's matter of main board, not Daughterboard
now, if you are talking abut preferences - Jensen vs, Cinemag or Edcor, in normal xformer configuration, that's other thing
I didn't found Jensen superior at all to Cinemag, and I'm liking Edcor more than Jensen, even if Jensen is certainly having more detailed sound
correction, this is good for F6
but, it will not transform it in Square Law OS :devily:
  • Jensen CInemag repeaters.zip
Needed some coffee as well..
Yes, that looks good for the F6. The CineMags are built with a surplus of pins, but they sound excellent. And Pa likes them, so enough said.
Thank you for providing a simple daughterboard solution for greedy boyz and girlz.
The elusive Square Law OS may need a different amp. I have enjoyed trying some different power transistors. The IXTQ75N10 proved to be a good high transconductance option. The IRFP048 worked well in the lower voltage F6 JFet build, and would also be suitable for higher voltage rails for the more adventurous DIY builders.
Very nice work on the repeater pcb Zen Mod, and quick.
With regards to the Cinemag's, are you using the high Ni version or the standard? Is there a separate part number for the PCB version with pins as against the standalone version with leads? I would like to compare these with the Jensen's.
Also, where are members buying them from in the US - can you order direct from Cinemag? There is no distributor here so will have to buy them OS.
I had that triple version already made whoknowswhen, as building bock for my concoctions
all what was needed is to draw Dimension (pcb boundaries) and produce set of files you see attached
and then - when Tungsten pushed me in right direction, deleting Edcor was trivial
xformer types you can see at render bottom pic
Cinemag - yes, directly from them
both low nickel and hi nickel are good; let mood decide
Pa, what was the reason for decision to use primaries in parallel, vs. using them in series, then just adjusting NFB to keep same CLG?
reckon, easier load to buffer
though, purely academic observation (even if ZM far from being related to anything academic; well, except devising Egocentric ACA :rofl: )
Looking at both datasheets, I think the connections are:
Jensen pin 1 to Cinemag pin 2
Jensen pin 3 to Cinemag pin 4
Jensen pin 2 to Cinemag pin 3
Jensen pin 4 to Cinemag pin 5
Jensen pin 5 to Cinemag pin 8
Jensen pin 7 to Cinemag pin 10
Jensen pin 6 to Cinemag pin 9
Jensen pin 8 to Cinemag pin 11
Hope you agree ZM.
here it is, as it seems that my brain is better while having night coffee, anyways
  • 2 repeaters for F6 ZM finally proper.zip
