Yes, I can hear it, but up close. The speakers are 88db sensitivity.
My last idea is mumetal. It will be delivered in the new year from the USA
I finally found a good place to store all the IPS daughter boards I've accumulated...
As they say on product review programmes on British TV,
BRILLIANT! ! !
Music Tree
Audiobear
Here is what you do!!! Since you have you one of those Fancy Free Range Trees.
Wire all of the cards in “Series” to a “Canuder Valve” then do the ole Triple Lindy in Parallel to the Flux Capacitor........I bet it will play Jingle Bells
Nice work
Audiobear
Nice work
They certainly do not look out of place on that silver Christmas tree - well done and very innovative. Will they still be around (not used) for 2021 Christmas?
I count 13 boards- what are you going to do with them all?
There are 7 daughter boards with one under development so a full set is 14 and soon 16. I have 20+ because I am making a second complete set for a Christmas gift M2X to my son. There are 13 on the tree because we had 13 hooks. Occam's razor.
Most builders are more than satisfied with the M2X--I certainly am. How often they swap daughter boards in and out has not been well-documented. Let's just say a DIYer can never have too many PCBs.
Audiobear
Nice work![]()
Oh, drat! I new I shouldn't have let the flux capacitor go! You have a spare you can loan me?
My M2X is in daily use and sounds brilliant, I have all the original DB's and a few others that X has done, but I have not tried any others yet apart from the Mountain View which I started out with based on a few recommendations around here. I am totally happy with the amp as it is now. But one day I will have to open the lid and try the other DB's.
I have been stuck on IPS#6 since the day after I completed the board several months ago. Before that I never changed out the original Ishikawa. I have been thinking about ways to make it easier to swap boards.
Depending if you have male or female thread for the input board mounting bolts......what about just using either "finger screws" or "finger nuts" then no tools are needed for swapping. I guess the contact pressure should be good enough.
I have seen some use a kind of smart mini connector so it is just to pull out the card and push another card in.
M2X- switchable inputboards
Hello M2X-builders,
I made a plastic - board with mounting studs (same pattern as on the M2X-main-pcb) for 3 inputboards and added a 4-pole - switcher.
Works beautifully for more than one year now. But I only switch between the
input-boards if the amp is off. Not during operation.
Greets
Dirk 😀
Hello M2X-builders,
Greets
Dirk 😀
https://www.oreillyauto.com/flux-500.html
You're on your own for sourcing the plutonium. My guy's all out.
Yes, Audiobear, there is a Santa Claus.
Hello M2X-builders,
Greets
Dirk 😀
To quote Mark: Brilliant! Great idea.
Very funny. After surfing the Dark Web for Plutonium these two guys in dark suits and sunglasses showed up at my door...
I spend a few hours making my own "test bench" for M2X input boards. I used a spare M2X amp board and just soldered in the "front end" and PSU connectors. Instead of Edcor I placed a 1k load resistor. This also to be able to have an easy contact point for a probe. A real Edcor as load will of course be much more realistic. But just to check/adjust DC and a functional AC test I think it is ok. On picture a 10 kHz saw-tooth is the input signal from a cheap generator. Output shown on a TDS 210. I used a Tucson input board for testing the "test bench". The real purpose is for IPS#6 which will be next.....
- The diyAudio First Watt M2x
