Totally fine.
Thanks, here's the build so far. Just need the regulator and case.
R2, 47K
Thanks. If I'm feeding this pre with a Pearl 2, the calculator tells me I should have a 2uf coupling cap in the Pearl as opposed to the 22uf that's stock. Is this right? I'm new to the world of coupling caps.
For what its worth, I feed my BA3 pre with standard Pearl 2, works wonderfully.
Russellc
nope
worst case will be 25K (atten.) in parallel with 47K (line Rin) , when wiper is on top position ( max volume)
25K in parallel with 47K is 16K. So input impedance would be between 47K at max volume and 16K at minimum?
no Bubba
I used 25K, with Pearl 2, anything I need to change for best operation, or is it all good? Seems to work fine, but you could fill battleship with what I dont know....
Russellc
I found this: A rotary switch for phono playback that presents three positions: mono, mute, and stereo.
Although it says to put it between the phono pre and preamp.
If it's leaving a phono stage, it should still be line level, a volt or more.
Something like this might buffer, that correct?
Stereo to Mono Converter Using FET Circuit Project
Basic buffers?
Basic Buffers
Basic buffers?
Basic Buffers
- The BA-3 as preamp build guide
