The Alpha Big Boy with Buttah (ABBB) 52w Class A Amp GB
Founder of XSA-Labs
Joined 2012
Sorry about your incident. The fact that it worked for months without issue and breaks at power on seems to indicate as you suggest, a short. Are you at least using CL-60’s or other NTCs on the trafo primary as a soft start?
Are your heat sink blocks grounded to protective earth?
Sometimes capacitance can be set up between the heatsink active and that can cause oscillation. The hum sound was the trafo vibrating due to the short. You may have a burr or some sharp point pike through the silicone insulator. Or are you using ceramic spacer pads?
Test the SLB part by itself with a new BJT. Disconnect the 0.1R to isolate the PSU. If that works, test with new MOSFET in place. Use an NTC this time in the primary trafo.
Have a DVM connected across the source resistor of the amp. Watch closely and when you flip power on, if more than 5A flows for more than 1 second switch it off and debug.
And now my shameful responses :)
No, I wasn't, though I think my APC does some amount of soft start (or at least has a slow blow circuit breaker / overload protection).
They weren't in my testing setup, I'll make sure to add that before I run it again. I had already planned for it on during my final build out.
I'm using a Silpad insulating sheet, planning on Berquist Red for the final build. Very possible either the sheet shifted or got punctured. I'll have to check it out more thoroughly and will likely come up with a better mounting strategy.
Which 0.1R is that? I'm guessing not the one thats part of the CRC?
I'll plan on testing out the cap-mx / PSU with a slow ramp up on my variac and then move to testing the MOSFET with a CL-60 or soft start in place. I'm pretty sure I already have one in my parts drawer...
Thanks for all the help. Hopefully I can report back with some good news and lay out some gotchas / lessons for future builders :)
Greg
I need a bit of assistance from the experts.
Took my time on this ABBB build. Built the V- and V+ cap mx first and tested them using light bulb inline and finally plugged straight to wall. All good, no magic smoke and was reading around 47v. Antek 32vac secondaries.
Finished the build on each amp and used the inline bulb again with no bad results, so plugged directly into wall. No sound. This is true of both amp boards.
I removed R203 and R223, measured about 49vdc on both positive and negative legs. Reinstalled them and measured +12v and -44.9v on the respective outputs.
I have written the voltages on the schematics. I am guessing I have an issue on the plus Cap Mx side. Gone over the board, checked solder connections, etc.
Thoughts appreciated.
Tnx
David
Here are several shots. I am reading 35vac on each secondary (TVA volts!). R203 and R223 are still out in these photos.
I haven't tried X's suggestion. I believe I may have mild dyslexia, so miss wiring a connector is definitely a possibility.
Thanks Vunce
Founder of XSA-Labs
Joined 2012
It does indeed get warm/hot and I use it as a way to measure the temp of the MOSFET body. I put a piece of Kapton tape on the channel so that the IR thermometer can get a more accurate reading. Mine is about 67C to 70C. The CPU cooler heatsink fins are about 50C to 55C. Some heat is conducted out of the L channel (a few watts) the bulk of the heat is via the CPU cooler though.
I'm thinking of using this amp to drive a pair of ESL57s, but would the 57s low impedance at high frequencies (~2R) cause problems at all?
I'm currently using a Bedini 25.25 (25 W x2) to drive a pair of stacked Quads (57s) and they sound awesome. Admittedly the Bedini runs at about 65°C but it has small sinks. This amp should not have a problem. My only concern is the protection circuit, some have had problems with ESLs I believe (hearsay)
Kevin
Hi X,
Quad ESL (57) impedance curve attached. The Quads (TMK) can take a maximum voltage swing of 32 V peak-to-peak and then you will get panel arcing. Stokessd here on diyAudio has clamp boards that can be easily installed to protect the tweeter/mid panels. Quad ESL57 clamp board?
A question as regards this amp - is it possible to use a total of four power FETs instead of two to spread the heat load? (please note I am not an electronics expert)
I have a pair of Antek AS-4225 transformers that I had been planning to use for a chip amp, but this amp looks very intriguing. I realize using these transformers would reduce max power, but would this amp otherwise perform well at the lower voltage?
My chassis has 330x140x50 heatsinks on each side. Think this would be adequate for the reduced power implementation?
Thanks,
Jay
