Sony vFET Illustrated build guide
both - what ?
P3 and P4 ?
or you already altered values of R34 and R35 ?
:clown:
check for P3 : upper leg of R35 and T10 , ohmmeter must read 0
check for P4 : upper leg of R35 and T12 , ohmmeter must read 0
I followed these instructions and they did read 0.
Now I have to order some replacement resistors for R34 and R35.
Getting parts in and replacing them may take a while because of my busy family life.
Regards,
Dan
The latest. I installed 392 ohms for R34 and R35. I measured 3.2V across both R34 and R35. I get around 1V at T6-T7 and the same across T8-T9. With a little tuning of these voltages I get 0V from T18 to ground. Everything seems to function as it's supposed to with the exception that the voltages across the two test points are still too low? Can't get too much over 1V.
Regards,
Dan
take absolute value of bias voltage , added 1V on that ....... and it'll be clearer
look at schm and think ........
Zen Mod take absolute value of bias voltage , added 1V on that ....... and it'll be clearer
Think? Although fun and interesting. This particular project has maxed out all my ‘available resources’! 😉
Regards,
Dan
Finally got to the bias stage. unfortunately I encountered problem on biasing the Vfets.
On one board, I can't lower the voltage under 20V (need to be 11V) with P1 at full turn. And on the other board the same, only on P2.
The frontend baising looks to go fine!
Need some guidance here please.
dantwomey, V-Fets are normally open devices, which means they will conduct current from drain to source even without a voltage present at the gate. This is why the bias supply is so important, the V-Fets have to be turned off or "throttled" before the supply at T3/T5 is present, otherwise they'll burn up.
For the first startup we want the V-Fets turned off (or throttled) more than necessary, just to be safe. The 2sk82 needs a negative bias voltage, so we initially make it more negative than necessary. The 2sj28 needs a positive bias voltage, so we initially make it more positive.
