Skar audio RP4500 need help!
It shouldn't be shrieking. It should play normally up to a reasonable level.
Does the bulb light up when it shrieks?
Do you see excessive noise on the rails?
Do you see a strange signal on the input of one inductors while the other is a clean square wave?
I forgot a previous question. On the oscilloscopes page, start reading at 'Scope Display Markings:' and read the next few sections. There are likely many sites online if you still don't quite understand. Basically, you use the scope display to determine the time for a complete cycle and use the formula F=1/time.
Ok Perry the bulb has not lit up yet.
I don't see any excessive noise on the rails.
And the inductors there's a clean sqaurewave on one side and the other side the signal im not sure about pic below to help both inductors are identical.
SCOPE SETTINGS FOR PICS 50mv / 10us x10
The negatives are generally connected together when they are connected in series. This is a fairly common practice in amps that need any significant filter capacitance at high voltage.
Voltage isn't an issue when working with the low rail voltage.
Attached shows one example.
So hook them up positive to positive instead of negative to negative?
Messing with the amp more I've found that the c6 cap on the driver board is connected to r4/r5 and when pushed on it's causes a lot of noise as well as the LPF potentiometer wiggling the potentiometers when you cut your finger on the LPF it makes the amp Buzz
