Simple DSD SRC for BeagleBone
Thanks Pavel. I have enough experience of your projects to trust your assessment; logistically it would be much simpler to get a batch of boards assembled so I'll dive straight in if there is any interest from others.
I don't think perfect sound exists!
Ray
BeagleBone is a powerful platform. Everything is limited only by your ideas and fantasies.
I had no plans to make hardware indication. Everything can be displayed via the firmware web interface. I was recently helped with the webdesign of the "Pure" firmware. In the future, I will expand it.
What software package gives all these applications? Looks very nice.
I am constantly haunted by errors with the numbering of the Amanero connector.
For DSC 2.6.2 you have to make the following cable:
Thanks! Is there even a Tidal app?
The "Pure" firmware is a collection of network endpoints for various audio protocols.
If you know a client-server application for Tidal, I'll try to add it to the firmware.
If you are using Windows on your main computer, then Tidal can be listened to through "Scream audio".
If MacOS - AirPlay.
Or via Android and BubbleUPnP.
Oops! Looks like you are using 45/49MHz clocks. Those should work fine as external clock sources for I2SoverUSB, but not directly as external clocks for Amanero. Amanero could be made to work too, but its a bit more complicated to do it with those since the clocks would have to be run though a divider.
