There are simplified SBCs based on BeagleBone - AntMINER L3 and D3
They can be purchased for as little as 5-10$.
I recommend using these boards. There is nothing extra on these boards that can affect the sound.
Thank you for the advice - I did not find any offer for these boards. Could you please point one out?
I am not familiar with the legal aspects of mining in Russia. But I see that now this equipment is being actively sold.
Доступ с вашего IP-адреса временно ограничен — Авито
Etc..
Etc..
Thank you, Pavel!
Yes, you can use this firmware.pure firmware can be used also for direct dsd in place of the "old" firmware that went for hqplayerd ?
I don’t mind. But before you run the group buy, listen for yourself.If Pavel has no objections, I am considering running a small quantity group buy for assembled boards.
Lately I've gotten tired of listening and searching for the perfect sound.
DSD'it was heard in Russia by only a few people. But they all responded positively.
any modification required ?
can i leave my current uEnv configuration ?
It is highly likely that nothing needs to be changed.
All settings are in the "optargs =" line of the uEnv.txt file.
as expected,
just tried... works perfectly with direct DSD output.
i have change optargs to copy my previous settings and that's it.
nice interface prettier by a long shot
BeagleBone is a powerful platform. Everything is limited only by your ideas and fantasies.
I had no plans to make hardware indication. Everything can be displayed via the firmware web interface. I was recently helped with the webdesign of the "Pure" firmware. In the future, I will expand it.
What software package gives all these applications? Looks very nice.
The "Pure" firmware is a collection of network endpoints for various audio protocols.Thanks! Is there even a Tidal app?
If you know a client-server application for Tidal, I'll try to add it to the firmware.
If you are using Windows on your main computer, then Tidal can be listened to through "Scream audio".
If MacOS - AirPlay.
Or via Android and BubbleUPnP.
... can it be used as a stand-alone DSD converter module?
Not as is. Seems like an Arduino and a USB board (or other I2S source) should be able to make it work.
Oops! Looks like you are using 45/49MHz clocks. Those should work fine as external clock sources for I2SoverUSB, but not directly as external clocks for Amanero. Amanero could be made to work too, but its a bit more complicated to do it with those since the clocks would have to be run though a divider.
- Digital Line Level
- Simple DSD SRC for BeagleBone
