Which shipping option is with the tracking, can you please confirm back?
I have tried to "simulate" delivery to, say, Hong Kong - everything from Canada Post Tracked Packet International and more expensive is tracked.
The other two less expensive options are not tracked.
Valery
I don't think Canada Post International Parcel Surface has tracking. It's painfully slow anyways so not a good option normally.
Canada Post Small Packet International Air seems to be a good compromise - although it's not tracked, it's fast enough. As far as I know, we never had a parcel lost so far, although we had some long delivery some time ago.
Jeff, please correct me if I'm wrong.
Oh you mean even the $19.09, Canada Post Small Packet International Air as well? As it shows as 6 to 10 business days I thought like this should also be a tracked shipping as usual no tracking takes around 30-45 days from Canada to India for my other parcels earlier.
Canada Post Small Packet International Air is actually my favorite form for shipping. No tracking or insurance but pretty reliable and delivers in roughly a week to most of the world. India and Italy hold everything up at customs for a couple weeks no matter what option you choose.
We did have a few parcels go missing last Christmas around the time of the postal strike here in Canada. I reshipped all that disappeared and as far as I'm aware everyone received everything since.
Have placed order
Raj
Yep - got it, thank you, comment on shipping is noted.
Valery
Balanced Input adapter update
Hello All,
For your information - we have slightly re-designed / improved our Balanced Input adapter (XLR / RCA) - V2 version is available for ordering now.
We will "automatically" send the newer version to those of you who have already ordered the older version within this GB.
Valery
Hello All,
Valery
@cl00sed placed an order for 3 pairs of boards and the same quantity of jfets including mine and one more member in the forum.
thanks
thanks
Is there a way to change the gain on these modules?
Hi Tuyen,
Yes, what kind of gain value are you looking for?
Hi Tuyen,
Perhaps something around 15-20db? I have vhex+ amp (Greg's unit), it sounds great, but on my high efficiency horn setup, its got too much gain for my system (29db?) My Pass F5 with 15db gain is dead quiet.
OK, 29db is a somewhat "de facto" THX standard gain for the home systems, that's why we normally use it. It's easy to set 15db gain in VHex+ just replacing the feedback resistor from 27K to 5.1K (the amplifier will remain stable).
Simpelstark is a different story - I will come back to you after the weekend.
9db in voltage gain means roughly 5 times, meaning 25 times less power...
That means if I listen to my system at around 50W, you get around the same volume perception at 2W. Is the horn setup THAT efficient? 😱
Hi
the new version of the balanced input board looks great! just placed an order in the shop.
Markus
Markus
Efficient horns can run on a couple watts very well. My Klipsch are 102 or 105db /W (Depending on which spec sheet you look at) so a couple watts can be quite loud. My system is dead silent with any amplifier connected to it though, including my VHex+ at standard 29dB gain. It might be worth investigating the source of the noise before altering other equipment to mask the problem. This can be very tough to do though.
Boards just finished manufacturing. I should see them early next week. A couple of the designs have been altered from previous designs so I'll assemble a set of everything and test before shipping out (Good excuse to build my amp internals). If all is well everything should ship out late next week.
- Group Buys
- Simpelstark+ ODNF amplifier boards GB
