Simpelstark+ ODNF amplifier boards GB
I see that using the discount coupon DIYAUDIO we get the 25% discount on the PCB board sets. But as per this thread and one of the posts you said that you will be giving the JFETs for $5. Your site does not take into consideration about this JFETs lowered price but still takes it at $9.99. So not sure when you said $5 is for a pair and this amp boards require 2 pairs. Please clarify.
The JFets are $5 per complimentary pair (enough for one channel). You require two pairs for two channels.
Hi Manniraj,
Jeff has mentioned the price in Post #26 as $5 for a complementary pair.
One set for a stereo amp contains 2 x pairs at a total of $9.90.
We don't discount them as this is close to the cost we've got them at.
Valery
Ok got it thanks 🙂
My chassis is coming along nicely for this amp build.
Order has been placed! And I have access to the the downloads, I’ve got a question about the schematic resistor symbols. There are ( — ) and ( /) inside the resistor symbols, what do the lines specify? Thanks.
Hi I have tried to place the order but there is no place to add the discount code mentioned on the forum. How to resolve this?
Thanks.
Hi Outtek,
The discount code entry field is on the Payment screen on the right, at the very end of the Checkout process. The example screen is attached.
I have also attached the screenshot of the mobile phone screen in case you order via the mobile.
Valery
