Hello Tibi,
Looking at your picture of the inside of Quantum, I noticed an extra capacitor under the mainboard under the ribben cable. Can you please explain. Is this one of the needed upgrades?
Robert
Where can I see inside pics of Quantum? No inside pics on Vicol website or FB that I can see. Would love to have a peek inside.
Hello Tibi,
Robert
That is a 1nF silver-mica in parallel with C19 and yes, the improvement is very noticeable.
Tibi
Hi again,
So C68 being a smd tantalum has polarity, can you verify orientation for +/- on pcb? Thanks again.
Steve
If you use tantalum, both C68 and C69 must respect polarity and you can detect polarity by measuring ground connection to power in.
Tibi
One picture is here Shigaclone MKII Black - The builders Thread
Other pictures are on twitter Vicol Audio (@VicolAudio) | Twitter
More will come on instagram Vicol Audio SRL (@vicolaudiosrl) • Instagram photos and videos
Tibi
Season’s Greetings, Everyone!
Tubo,
Beside modification addressed in this thread, new mods address mechanic, pin diode Vref, laser ccs and several other points on main shiga mk2 board.
- on mechanic, over laser I add now a 1nF silver-mica in parallel with 100nF Vishay. For lubrication I use a teflon based one - it was presented in this thread.
- on laser ccs, across C19, again 1nF silver-mica
- finally U5 ADP151-2,5V ref for laser PIN detector is in place, but this require some extensive board modifications - I'll come back later with more pictures and details.
- now I use mini regs in places of V2,V3 and V4. For V1 I use LF50 as an alternative to LT1086-5 with excellent performance - note that these regulators need 100uF soldered on the output to eliminate any oscillations. Salas D-reflector for V1 and V2 are also a nice upgrade.
- in place of C24 I use a polypropylene. This cap greatly affect s/pdif signal quality.
- instead C48 and C51, I use now a single cap of 100uF oscon or polymer
- As foil capacitors are getting cheaper and smaller, I use polypropylene for C28, C30, C31, C38 as well.
- For C13 Sprague B1514 cap bring some very nice harmonics.
- if you look for a better clock, than I recommend Neutrino2 from newclassD
Tibi
Tubo,
Tibi
neutrino 2
Tubo,
Tibi
Sorry, I was going to ask is the neutrino 2 as good as the big brother neutronStar2? The neutrino 2 is more affordable.
Hi.
FYI
I build in my (very old lady) Esoteric TEAC P2 the (new print/better concept) big brother NeutronStar2 with the new (print) PSU
It was desolder/solder/play ...
It's worth ... splendid
It's al music ... I like it.
Karel
Will board work with U5 [2.5V ref] in place and 2 specified capacitors and no modifications?
Steve
Hi Steve,
Yes, the board will work just fine with AD151-2,5V reference in place, but will not bring expected sonic improvement.
You need to mount only U5 and C69, cut the U5 output trace immediately after U5 output. Remove L1 bead and grab a wire from U5 output to C11. On C11 mount a 10uF tantalum or oscon in parallel with a good quality 1Kohm resistor - preferably a metal foil one.
This mod will provide a very clean 2,5V reference to pin detector.
You'll love instrument extension and decay after this mod.
Quantum ultra high-grade have this mod inside, It was compared with players above 18000eur and now used as reference along some very big names.
Tibi
Do you have an image of this mod in place? Does silver mica stay in place Thanks
Steve
I'll add some.
In the meantime, here are mods on CD mechanic.
Tibi
Mods for new CD mechanic.
There is same 100nF PIO across turntable motor.
Tibi
Tibi
- Digital Source
- Shigaclone MKII Black - The builders Thread
