woow
this thread still alive!
Mad_K
I was with you in beginning of 'One Transistor amp' thread
and also a bit in this SEWA project, if you remember me.
http://www.diyaudio.com/forums/showthread.php?threadid=73598
http://www.diyaudio.com/forums/showthread.php?threadid=73598OTA - One Transistor Amplifier
I while back I posted a amplifier design with only one transistor. I named it SEWA (Seven Watt Amplifier). It seems most people interested in the design actually wanted LESS power (power dissipation I guess). While the SEWA design has evolved into something different (coming later), I have renamed this design OTA - One Transistor Amplifier. Attached is the revised schematic. Enjoy! And please let me/us know if you decide to try it
I really like your work 😎
And your way to go.
As 'audio father' Mr Pass did put it:
Keep it Simple, guys!
Hi Mads!
Can you open Eagle files?
I find an interesting preamp (the Kaneda preamp), but the schematic and PCB pictures are in eagle format. I tried to open with my eagle version, but I can see nothing......
Tyimo
Tyimo
Hello again lineup 😉 Thanks for the roses. Your presence is more than welcome. A lot of guys here are interested in tube preamps/drivers for SEWA, maybe you can help?
Mad_K said:Hello again lineup 😉 Thanks for the roses. Your presence is more than welcome.
maybe you can help?
My tube knowledge and practical experience is very limited
at least compared to those in TUBE & VALVES forum.
I really would like someone start a topic in Tubes,
about preamp project for SEWA.
As many TUBE Guys also reads Pass Labs forum,
several people with good Tube knowledge, alread may know about SEWA.
In Tubes Forum
Topic could be this ( or similiar ):
Tube Pre Amplifier for SEWA 7watt Class A MOSFET
okay, I go create this topic now, myself!
With such a title it may attract a few active posters 😉
See you.
tube preamp for sewa
The NEW TUBE Topic
for construction of tube pre amplifiers for SEWA
Tubes >Tube Pre Amplifier for SEWA 7 Watt ClassA MOSFET
http://www.diyaudio.com/forums/showthread.php?threadid=85952
Welcome!
In Tubes Forum
The NEW TUBE Topic
Welcome!
A comparaitive audition between a tube driven SEWA and a well designed 300B amp might be very interesting and revealing!
Both very similar power and SEWA much more cost effective IF as good ;-)
Actually, SEWA has about 10% distortion with the low 22,5V supply driven full out. It is more like a 3W amp, but it clips gracefully, and it IS possible to get 7W from it. Running it on 30V rails with 5K6 R1(like Tyimo) I would rate it 7W 😉
Have a look at the latest OTA schematic I just posted, it should please you tube guys. Even more linear. Just adjust the input Z (47K connected to 100R at the gate) to suit whatever is driving the gate. 100K is a good value, but 470K not a problem either 😉
http://www.diyaudio.com/forums/showthread.php?postid=998017#post998017
I am not a one eyed tube guy BUT I am interested in a comparison.
If a hybrid can equal a DHT SET itt is a great breakthrough for price / performance!
I checked your design earlier ( few minutes ago). It seems to me that cap quality will make or break this design.
Yup, the coupling caps are very important. I have had good results with Elna RJH (for low power version, 4700uF) Comparable to Panasonic FC, Sanyo MV-AX/WX etc. For higher power I liked the Evox Rifa PEH 200. In my next OTA build I am going to use a chassis mounted 10000uF 63V PEH 200 bypassed with a 250V 2u2 Rifa PHE426. It MAKES 😉
I don't want to be seen as a cap snob but have you tried things more exotic than RIFA? Like Hovland, Auricap or Mundorf? I would see something this quality critical on the input cap at least.
Also I wouldn't under-estimate the effect of that bias bypass cap nor the last power supply electro.
With very simple low parts count zero feedback designs like this, the catch is you must pay up for the absolutely best available parts if you want the most out of the design. I know YOU know this.
cheers,
Bart
cheers,
Bart
Yes, I used to be fantaic about these things, but you know I am an engineer, so I guess that side of me keeps me from paying through my nose for any "audio" components. I use the best I can get from my electronic component supplier ( www.elfa.se ). For better sound, it is better to buy bigger/better trafo, supply caps, heatsinks, mosfets, voltage, current etc. IMHO. I know the passive components can significantly change/better the sound. I leave this to the individual tweaker 😉
BTW, there has been a lot of talk and little actual building to be seen in this thread. What we NEED is to see some pictures of some ratsnests acually making music. Come on gys, show us, show us! Someone must have buildt something 😕
engineer accounts only for getting close to an approximation of good sound.
from there on in we can only trust our ears - admittedly subjective by personal bias but amazingly often agreed upon by large groups.
we pay larger sums for better parts hopefully only if these parts offer a worthwhile benefit / cost to our ears!
you cant get there merely as you say by bigger everything, sorry! you are wrong. in every place you mention, if correctly engineered, once quantity is adequate quality is everything.
look at the very best pre-amps from CAT and Conrad Johnson. This later refining very simple almost 30's designs for 30 years. They won't have an electrolytic capacitor ANYWHERE! both make their own caps.
I am with you and I completely agree/understand these things. Remeber that I said "bigger/better". What I said, counts for me, and my experiences. I'm really not into listening to sound, only the music matters to me. Let's not get into this parts debate in this thread, please 😉
- SEWA - Seven Watt Amplifier
