• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
SDA-400 Professional multi-way
For the input im using a balanced wire.
blue +IN / white -IN / shield AGND on SDA-400 side
and on the DAC side I connect white cable and shield together. I'm using this setup because I don't have small jumpers avalaible. Since I'll have to buy some resistors I'll buy some jumpers in the same time 😉
Roberto now that we know the resistors has burn what do you think could have caused this?
Smoke the res,obvious amp turn in big Unbalanced condition. in your case I'm sure a auto-oscillation. (or you have smoked power mosfet) but in this case, the dps-400 stop,and is not able to re-start (in presence of short-cut I mean). also,you can measure simple with tester, from Power DC pin to gnd in SDA, if have short-cut just before you switch-on. (in presence of short-cut,or current >500mA,the dps-400 LED, blink continuos,smps not start ).
Input need very short connection to AGND under SDA or via JMP.
🙂 ... with your connection, you have create a perfect "Link" to capture signals.
I have protected very well this amps...hope 🙂, also, The output stage (toroidal incluse) it's made for big current output or 500-600w quiet.
Maybe,other diy with other types of amps and smps , in the same circumstances , would have destroyed smps and amp ...and speaker. I mean,the protections are very important.
Hi, this is the kit SDA-400-Mono € 120 + UPS
Also, the Stereo sda with Nichicon, as I said before. € 230 + UPS
Available identical at 120Vac (this version uses direct conversion on the DPS-400 (no voltage doubler in main filter cell), is unique in offering performances as power and dynamics, far away from the transformer or traditional smps.
Info
These which I have shown, are products ready (final test need) for
DrizztDo & Vis
Hello,
Just a quick message to say that I received my package yesterday.
I only had time to quickly unpack it. That took some time due to the quality of the packaging.
I will have more time this week-end to look at it in detail.
Thanks Roberto.
I am looking forward to try those amps.
Vis
At end, is not bad that customers see "how is made" the compact Dps-400.
I want to explain in a few steps, some design strategies that will certainly have raised the cost slightly, but they allowed me to obtain a very low irradiation RFI / EMI and Ultra Low conduction of harmonics, via DC output (essential for audio).
We start just with small module Osc./Driver...next step.
Hi Vis,
very thank for shared your products.
If you need some advice, I'm happy to help.
P.S. maybe these photos were better on the thread of the GB. also for discussions on the assembly, may also be valid for the other.
apart, this thread will become very hot also. eheh!
Hello,
So this is the content of the package I received from Roberto.
General View
DPS-400
PBTU-3
Amplifier module
And finally all the connectors and stuff
So let's get to work
Cheers
Vis
Hi Vis,
You will not be dissapointed at all! I have 2x kit 3 which is SDA-400 and DPS-400 together and all I can say for now is wow! First time I hear a Class D amplifier that is not aggressive in the upper range and not over exaggerated in the mids. Sounds really fluid with a very good soundstage. I will advise however to not use the included potentiometers, connect directly and use a good preamplifier makes a good improvement on sound to my own liking.
Right now, my friend is evaluating the amp in his own setup and really liking it. I plan to bi-amp a pair of 3 ways with these modules.
Have fun!
Do
Hi Do,
This can be given by the potentiometer which is also inserted on the (-IN), but does not worsen dramatically.
I agree for direct connection input for sure.
Vis:
Thanks for shared your products.
I recommend changes (removal of the pot), only after you've tried everything.
however, I will post a simple diagram for the jumpers to do.
INFO from AudioPower.
Some expect that new stocks of the DPS-400, arrived!
just in time for refreshment of the shop.
I wanted the services assembles with my last review (equal to the GB version).
A new version dedicated to ICEPower DPS-400-IP
DPS-400-LV (ELNA caps and Nippon Denso High Voltage cap) 120Vac Market.
DPS-400 Standard (400mA startup current & 10A instead of 8A.
All included with customization, DC Power, and Aux (VN-REF or GND).
Others good...coming soon 🙂
Tomorrow I continue with description of the Dps-400 In Side.
I tell about voltage on the analog INputs, not the offset on OUTputs.
It is folly 🙂 to measure the input with simple tester, considering it's a D Class. (I mean, testers capture the hf also), that the fortune sda, HF has a filter at the input stage.
let me see how it is currently connected (cables),so I can help you, I'm sure that the problem of the smartphone is the capture of hf signals.
I'm not able to figure others reason.
