Salas DCG3 preamp (line & headphone)
Joined 2017
I got myself a star quad for the headphone-connection... But:
Do I connect the shield as well as the inner pair to ground too?
Or should I follow the SCM of the data sheet (although a balanced microphone connection)?
  • GAC2017page12.pdf
diyAudio Chief Moderator
Joined 2002
Thank you again!
Good I asked, I would have connected the shield at the other end… (like, connect the shield on the „lower“ end of the chain?)
Yeah, but this V1.03 board isn't already bridged for channel grounds. They are independent. Bridge point will happen at the HP jack's common ground pin and its easier to also refer the shield there.
Joined 2002
Yes, input side select does that. Some would go bridge at the volume pot even when using just a two inputs rocker switch. Or run a busbar through all RCAs. TRS jack classic headphones cable forces an output side channels ground bridge.
Still open policy in the main board is good not to lock you bridged if different ground schemes must be implemented.
