Salas DCG3 preamp (line & headphone)
Inputting 1khz square at 500mV it comes out clean until I turn the volume up.
When at full volume there is pronounced ringing.
Tried modifying input filter without results.
A zobel 10r wirewound 100n on the output does little
A 10nF cap directly on the output removes the ringing.
A 3.3nF cap on the output also removes the ringing.
A 3.3nF cap with a 10ohm non inductive resistor also remove the ringing.
You should not be putting a 200kHz square wave through any audio equipment unless you know it is designed to handle those frequencies.
200kHz sq has frequency components that go out beyond 2MHz !
10kHz sq has frequencies that pass through normal output Zobels.
By the time you have raised this to 20kHz the Zobel will start to run warm. The resistor is starting to dissipate significant power and the ESR inside the capacitor is starting to dissipate significant power.
I would never use 50kHz square waves through an amplifier, yet many on this Forum do that and worse.
The first harmonic of 50kHz sq is 150kHz
The capacitor of an output Zobel has quite a low reactance at this frequency. Even less to the 250kHz and 350kHz of the 2nd and 3rd harmonics of the sq.
you cannot check for clipping/overloading when passing a sq.
You should be putting in a low level lowish frequency sine and checking you are well away from clipping and then switch to a 1kHz sq, at the same peak to peak level. That ensures the audio stages are not overloaded.
Is your gain set to 3times (+10dB)?
that makes your output ~1.5Vac ~2.12Vpk
That is a mighty high signal. Then you say you turned up to "full volume" !
As I always try to visualize what I am doing, here we have some pics.
1st - response without zobel
2nd - response with zobel
Well, I am sure it is because I did not use the most correct models and I am not an expert in simulations.
Anyway, I am now listening to your preamp and it sounds really outstanding.
I listened a bit with my entry level headphones (32ohm AKJ) and sound is really good.
I fed the preamp from the soundboard of my pc and found that it does not play very loud but did not verify the output value of the pc.... must return there latter with high spec headphones.
The 598 is sensitive but 130-150mA will do bit better THD on 32 & 50 Ohm headphones. You may listen to them with your now bias first. 3x is usually all you need, should be much enough for the particular ones anyhow.
