Rockford Fosgate T2500-1bd
I rebuilt the output driverboard and the 7k signal went away . I have audio on some of the pins of the master slave switch . 1 row I see audio on the pins the other row I don’t see good audio on the same pins .
not sure if this is normal for this amp or not but on U106,107 that sit behind the switches I get 13 volts on pin 1 of both opamps
Yes I still have voltage on pin 1.
here’s a pic of the switches
