The link sends the browser to the last post so it skipped several posts.
Did you have R137/138 reversed?
Reinstalled R137 but still get no audio on driverboard pin 1
mare U101,107 supposed to have 13 volts on pin 1?
Bridge 1-2. Voltage on pin 1/2?
Are the switches back in the board?
If so, set the master slave switch to master and post a photo showing each pair of terminals that are directly connected?
If I bridge pins 1-2 on U107 I still get -12.57 volts .
I took the switches back out to spray them and clean
Are you 100% sure that pin 3 is 0 and pin 1 -12?
If the switches are out, measure the resistance between terminals as described and install a wire jumper in place of the terminals that read 0 ohms.
Set the phase switch to 0 and install jumpers like above.
Did you try dripping contact cleaner through the holes in the top? It should have flooded the switch.
Ok I reinstalled the switches after cleaning them and tested for audio using a 100hz sine wave from my test oscillator .
The amp had output .
I will recheck for audio using a head unit as signal and confirm and post back
I think that's due to a dirty switch. That's why I wanted you to replace the switch with jumpers. If the switches are in it, you can leave them. Post a photo.
- General Interest
- Car Audio
- Rockford Fosgate T2500-1bd
