Rockford Fosgate T2500-1bd
If I remove the output board from the amp . The whining goes away from the transformer and the outputs remain cold . I’m wondering if one of the ic’s is defective . I guess I’m gonna have to order new ic’s again and see if that fixes the issues .
Also I noticed that for a second I had very low audio then it went away . So I’m guessing something on the output board is still defective
If you're repeatedly installing the driver board, using jumper wires (as shown below) will likely be a better option. Search eBay for 'Arduino breadboard jumper wires' to find jumpers that are easy to work with.
I can't tell you that you absolutely won't need to do anything else.
