rockford fosgate t15002 amp troubles
OL and 0 ohms are exact opposites. OL means that there is a broken/open connection. 0 ohms (or whatever your meter reads when you touch the probes together) means that there is a direct connection.
Go back and try to find the direct connections between the SMD resistor and the pads for the jumper.
To get the jumper soldered back to the insulator, you'll need to use the torch. Use a black binder type paper clip (see attached for an example) to hold the output transistor in place.
Completely remove the jumper from the main board and clear the solder through-holes for the jumper (on the main board).
If the jumper is bent, reform it to lay properly on the insulator and have the legs fit into the through-holes. Make sure that the insulator is at the proper angle when checking the fit of the jumper.
With the binder clip in place, heat the insulator with the torch until solder flows freely onto one of the solder pads for the jumper. Place the jumper on the tinned pad and heat it with your soldering iron. It should solder on relatively easily if you heated the insulator well and didn't wait too long to solder the jumper. Solder the other two legs of the jumper to the insulator.
Place the board in the heatsink and screw the insulator to the wall of the heatsink. Solder the three legs of the jumper to the main board. Remove the board and solder them from the other side if the solder didn't penetrate the vias fully.
If this is the only thing that's changed from the last time it was powered up, power it up via a 30 amp fuse. Does it blow the fuse?
Missing attachment from last post.
This is simply an example of the types of clips and the placement. This amp was being repaired and was simply convenient to use. The tape (difficult to see) is being used to keep the heatsink compound at bay. You would NOT have tape applied when heating the insulator.
