The other possibility that comes to mind is the 12V rails coming up at different times. Maybe as a test the op amp can be externally powered and powered up before the amp is started.
This is a good one! Most likely this is the case...
To my point of view C12 is a filter for d.c voltage after D7 D8 rectifier.
Yes, C12 is part of the filter, D7, D8 are just for the opamp's input protection.
If you ask me i'm using TL072.
Tl071 isn't pin compatible.
but post1610 shows a single with out on pin6.
Post #1610 is a Valery modification using LF411.but post1610 shows a single with out on pin6.
This is my next stepThis is a good one! Most likely this is the case...
I will use the +/-15V from vz-x4 power supply board.
TL 072 & LF412 act the same on power up.The power up thing actually makes sense. TL072 will act strange if it's inputs are near rails on power up which would give a wild output. C13 would hold this output voltage for a short period.
The external supply +/- would need to reference the same ground as the op amp. If he's using the supply for the NS-OPS, he'll already have a +/- 15V supply referenced to the same ground built into it. Too bad the rail mosfets are bypassed.
Those diode are between the + input and ground, not the - input.
That appears to be a mistake I had not noticed. The input protection diodes should be between +IN and -IN.The external supply +/- would need to reference the same ground as the op amp. If he's using the supply for the NS-OPS, he'll already have a +/- 15V supply referenced to the same ground built into it. Too bad the rail mosfets are bypassed.
Now does that make a difference to start up behaviour?
separate +/-15v to offset controller
No, this solution just hides the problem.
What i mean.
Amplifier's offset start from about 400mV if the separate power supply start up about 12'' before the main power supply.
Amplifier's ofsset start from 3 volt when separate power supply start up about 5'' before the main power supply.
To my point of view this act exactly as when common power supply was used.
Another find is that offset is 3v when i forgot to startup the separate offset controller power supply.
What i mean.
What i mean.
What you can try to clear the situation - remove the opamp and ground the output pin, where the opamp's output was, to ground. Start it up and see the offset behaviour. I think, it will start from 3V. Then we know what to do
Hi Valery,i will try your suggestion tomorrow.What you can try to clear the situation - remove the opamp and ground the output pin, where the opamp's output was, to ground. Start it up and see the offset behaviour. I think, it will start from 3V. Then we know what to do
Thanks.
Yes you are right,start up from 4v and stay here.What you can try to clear the situation - remove the opamp and ground the output pin, where the opamp's output was, to ground. Start it up and see the offset behaviour. I think, it will start from 3V. Then we know what to do
It may be caused by the difference in input LTP's base currents due to significant difference in base-to-ground resistors' values.
It would not be a problem if the input devices would be the jFETs or the tube triodes, but is a problem with BJTs.
For a test, we can insert an electrolytic capacitor in series with NFB resistor, placed between the -IN and the signal ground.
But the base current is of the order of 6uA. That was confirmed some while ago and confirmed that the LTP was reasonably in balance (just within that tolerance of ±10%).
6uA across 22k is only 132mV.
changing one side to 11k only creates a difference of 66mV. That very approximately should become the new output offset.
- Revisiting some "old" ideas from 1970's - IPS, OPS
