QUASI Amplifier for Beginners
apex vu pcb.
hi AndrewT
i will use mje15030/31
but i was wondering how my dj amp has bd139/40 with rail voltage 54 volt
they are forced air cooled but without heatsink. :confused:
the amp is robust and drive 2 dual 15" cabinets.
dear sanju
i think that dj amplifier are huge ,1000watts and with mosfet transistors.these dj are 16 ohm 12 inches speaker.do you have knowledge about dj commercially available in market.khanks ur masood
The 0.22Ω in each individual transistor will be dissipating about 1W average power assuming 300W/4Ω with four pair of outputs, so a good quality 3W is probably adequate.
Remember that most resistor ratings are specified with a Delta T of 250°C, so a 3W part running at 1W will have a Delta T of 88.3°C above ambient. This will be over the boiling point of water if the amplifier is run at full power for any length of time, but it should be OK.
