QUAD 63 (and later) Delay Line Inductors
AX tech editor
Joined 2002
No I also demo'd the set. Maybe Holger missed that.
There were others taking pictures. I will check.
The presentation should eventually be on line but it may be restricted to ETF participants.
It was a nice event, interesting speakers (mechanical and human), and a great venue, an old castle.
What I found less interesting was dragging the large ESLs up 24 steps of stairs ;-)
Jan
AX tech editor
Joined 2002
A few pics of my setup.
Jan
Reactions: 1 user
Joined 2005
One hour of work, and the coil board was taken out, checked, and reinserted - problem still persists. Another listening test with a signal generator indicates it is the panel on the top of the speaker,....
See attached picture, I checked the DC resistance of all coils in series (only one half shown) and tried to see if rattling them would cause a change, but nothing happened. All coils measured 3.1 ... 3.2H (measured with a PEAK LCR meter at 1kHz).
So, as ESL63 and others said, its the panels, not the coils. Thanks a lot anyway for the help!
Joined 2004
Jan-I see you have absorbing panels behind the quads. They help a lot. An important trick I have discovered- arrange the panels to reflect from Quad to the other panel. You get several benefits. First the reflections don't go back through the quad directly. Second you get two stages of absorption and its basically free.
