Q17 Sigma22 Regulated Ultrastable Ultralow Noise Linear Power Supply +-50/60Vcc
The maximum current tested on a continuous pure resistive load was 4,13 A at 55Vdc output, 61,5V input, for aprox 3 minutes. These are extreme conditions. It can't happen while listening music on speakers, to actually see 4 Amps current absorbed per rail.
Hello,
I have a question about the sig22 circuit.
The original circuit puts a Polyester capacitor of 3900pF in Q12 and Q13. As I need space to move some components, could we put a ceramic COG 2.5 there instead?
Stef.
4A into 8 ohms is 32W peak value. For music that corresponds to about 23Wrms.
Half of that in 4 ohms. Not really extreme.
Jan
What is your objective on this subject Jan?
What I can say is when you listen to music at normal level at home, in your living room, you only consume a few Watts in reality.
These continuous consumption tests only serve to prove that the board does not explode or collapse if used. You don't have to look any further. The rest will be done in the real world, by trying it used with an amplifier board (and measuring it too).
We're not there yet. Don't bury the man before he arrives. 😉
Stef.
