Post your Solid State pics here
My latest creation -4
Electronics detail
Slots... I think you though of slots for knobs. Make hole in front panel (for example knob_diameter+2mm), then weld bottom-closed pipe (choose its length, as you wish the knob to hide into case), but before cut that pipe on side, just to be able to screw knob to potentiometr. On the photo you can see what i mean.
Ventilation rows, yes, they ware made by cnc milling machine.
Update: Don't change your post so qucik ;) Material used is an acid-proof plate. For frame on bottom - 1.5mm, and for cover - 0.7mm. It's painted.
Thanks esh0 for the informations. I am obliged to you.
Fotios
That means you need a chasis :rolleyes:
(Hi Fotios) I will post some fotos of an amplifier made 12 years ago by a friend of mine, as soon as i can.
The chasis was made from raw aluminium plates entirely, the sides were the heatsinks. I think you already have more than the tools needed for the job :D
By the way, I must have more info about that 15E bending machine of your's :drool:
Ãåéá óïõ ðáôñéäá. Ãåéôïíéá åéìáóôå ðåñéðïõ, áðï ôç Äñáìá åéìáé. Ôé ëååé ç Êïæáíç? Å÷ù åíá ðáëçïöéëï áðï åêåé, ëåãåôáé Ãéáííçò Ëïõìðïõôóêïò êáé åéíáé ìåãáò ìïõóéêïò, çëåêôñïíéêïò êáé ôáâëáäïñïò. Áí ôïí îåñåéò, äùóôïõ ÷áéñåôéóìáôá áðï Öùôç Áíáãíùóôïõ êáé áò ìïõ ãñáøåé êáôé. Êïéôá íá äåéò ìå ôá êïõôéá ôé ãéíåôáé. Ï åíéó÷õôçò ðïõ âëåðåéò óôç öùôïãñáöéá êïóôéæåé ìå êïñõöáéá õëéêá 350 åõñùðïõëá, êáé åíá êïõôé ðïëõ ìïõñáôï áëëá ôïóá. Å, äåí ôñåëáéíåóáé? Åôóé áñ÷éóá íá áãïñáæù äéáöïñá ìç÷áíçìáôá. Áõôç ôç óôéãìç å÷ù çäç åíá öáëôóïðñéïíï, ôç óôñáíôæá ÷åéñïò ðïõ ôçí åöôéáîá ìïíïò ãéáôé åíù âñçêá åôïéìç áðï Áããëéá Óôéò 45 ëéñåò ìáñêáò CLARKE, ôá ìåôáöïñéêá çôáí 80 ëéñåò!!( èá âãáëù êé áëëåò öùôïãñáöéåò ôçò ãéá íá ôç äåéò êáëõôåñá êáé íá ôçí êáôáëáâåéò). Ôùñá øá÷íïìáé åéôå ãéá åíá óáðïñô ãéá ôï êïëùíáôï ìïõ äñáðáíï, åéôå ãéá ìéá êïìðëå öñåæá. Äõóôõ÷ùò ïé ôéìåò åéíáé ðáíáêñéâåò óôçí Åëëáäá åíù áðï Ãåñìáíéá ôá ìåôáöïñéêá åéíáé ðáíáêñéâá ãéáôé ïé öñåæåò æõãéæïõí ãõñù óôá 140 êéëá. Ç ïéêïíïìéêùôåñç öñåæá ðïõ å÷ù âñåé ùò ôùñá, êïóôéæåé áðï Ãåñìáíéá 950 åõñùðïõëá ìå ôá ìåôáöïñéêá. Ïðïôå äåí îåñù ôé íá êáíù áõôç ôç óôéãìç. Èá äù êáé èá áðïöáóéóù. Ðáíôùò ç öñåæá ÷ñåéáæåôáé ãéá íá êïøù ôéò ó÷éóìåò áåñéóìïõ óôá êáðáêéá (áò åéíáé åîù ïé øõêôñåò, ï ìåôáó÷çìáôéóôçò êáé ïé ðëáêåôåò ôé ãéíïíôáé?) áëëá êáé êáìéá ôåôñáãùíç ôñõðá ãéá äéáêïðôç ñïêåñ. Áóå ãéá ôç âáöç êáé ôéò ôáìðåëåò, áëëï ðñïâëçìá áõôï. Ãéá íá óïõ êáíåé êáðïéïò ìåôáîïôõðéåò, èåëåé ôïõëá÷éóôïí 50 ðñïóïøåéò. Áõôá. Áí å÷åéò êáììéá éäåá, ãñáøå ìïõ êáé ãéá áõôá.
Íá ìéá ùñáéá öñåæá
Ñéîå ìéá ìáôéá óôçí éóôïóåëéäá ìïõ www.eal.gr , èá äåéò êé áëëåò éäéïêáôáóêåõåò åêåé.
Öùôçò
