Playstation as CD-player
PlayStation CD-player with LCD, in progress pt.2 - YouTube
Boots from cartridge, but needs bootdisc (any official blackdisc).
Disappointment!
So I finally got that PS1...and it turned out to be a 5552 instead of the 1000 that I initially thought it was 🙁
Read somewhere that it does sound good but was so disappointed that didn't feel like hooking it up 😡
Do these have enough input voltage to drive a TVC???
ps-1 troubles
hi, my son and i just modded two ps-1's by removing the six dc blocking caps and put a jumper and lifting the two muting transistors and they played great for a while but they both started,im not sure how to explain it ,the sound started to pulse and distort ,its's obvious we've done something wrong,when they did play good it was very impressive,if anybody has any ideas we would be very greatful, being were new at this, thanks so much. . . tim
Hello, You need to check you wiring and socket connections again and post some pixs so everybody will see it.
All playstations that will build up to date ...
