PHONIC 740 mixer-amplifier
yes I noticed it. after successfully start with light bulb it will be fine, but without it maybe next day, next month... it will burned at startup.
also NTC needs time to cooldown to reset it's value, rapid on off will burn IGBT
Without light bulb tester(smps directly connected to main voltage) smps burns instantly!
It is something that i haven't tried.....to short the light bulb without to unplung the main voltage.
I will repeat here that PHONIC selling in the past a repair kit.
The NTC, among with others,was in the kit
Who know if it was the original as in the part list or a different one higher ohm(as your recommented is)?
Αll voltages in the secondary were in accordance with the schematic.
+/-54v
+/-35v
+/-15v
+48v
I beleive that there are two posibilities.
1)the IGBT that i used isn't compatible.
2)something was wrong with the delay capacitor(C913=22uf).
In my test circuit smps CAN'T START AGAIN before a delay of about 15''
I had test the repaired smps(with the light bulb connected)and it wasn't any delay time between repeated on-off-on.
If you will find some free time,please can you compare two IGBT,the on in the part list IRG4PC50W AND the second that i used RGT40TS65D.
ok so it works on the current limiter (bulb)without the load but burns up without bulb in place and under load correct?
to me that still says there's a problem with the load whether it be the output,the low voltage rails there's something going on...
Yes, it is a vexing fault…. The waveforms of post 54 say it all - if the burn up also happens with NO Load. It’s only running around 80% duty cycle, so unless those off times get just stupidly spread out the converter itself will run fine. Not even requiring a resonant mode. Those effects are load dependent.
Whatever the problem, it’s happening right at start up, and the resistance of the bulb limiter mitigated it. If something is happening out of sequence at start up (perhaps forcing both IGBTs on for a few microseconds) it’s going to be very hard to capture. In that case, slowing down the start up is the only way. If the “NTC” has a shorting relay it’s probably really a “PTC” which emulates the light bulb. You may just need more hot resistance to be safe. It sounds like that IR chip was just a bad idea from the start, and that an old TL494 and separate high/low side driver chip - from IR - would have been better.
Another possibility is that the 3.4 uH in the transformer just might not be enough to allow empty capacitors on the secondary side to charge safely the FIRST time. This would also show up at extremely heavy load, as the charging pulses would get to dangerous levels. Normal light loads would run with no problem - AFTER successful start up. This is just a design problem. The solution would be a softER start up, and putting about 20 uH in between the secondary rectifiers and the caps. That will slow the charging down. It’s a LOT easier on the rectifiers and caps too. You lose a little peak power (supply drops a little faster under load) but no RMS power (it drops to the same level at full load, dictated by the duty cycle). That duty cycle looks like about 80% to me - which should allow a sloppy, hard switched circuit to work safely.
Thank you!
Speaking for modifications what's your opinion if i place a small circuit around LM555 to control the relay,given more time delay at start up?
Like in this circuit.
Sorry,thermistor is an NTC type.
Checked.
Cold is 10 ohm.
Lower resistance as go hot.
Another modification...10ohm/5w resistor in series with the thermistor?
Caps are pretty small, and it does use filter inductors so the designers at least thought THAT through properly. If nothing there is fried it shouldn’t have excessive draw off the secondary. I’ve seen them use 4700uf and no inductance save the leakage reactance in the trafo. Ive blown hexfets across the room doing that myself without a ramp-up in the converter duty cycle. Got to be a problem with the switching controller chip section itself.
Speaking for IR 2153.
The part list show the IR2153D.
The first placed by the manufacturer is this in photo.
In this circuit it is an external diode from pin1 to pin 8.
I'm confused 😕
