Pearl 3 Burning Amp 2023
Wayne is a firm believer of “keep it turned on all the time”, as far as I can tell…
I’m judging this by looking at the Pass Labs website and seeing that none of the line-level devices have power switches on the front.
SoCal Edison
Month of December 23
900 KwH
$450
Have any electricity generating unicorns nearby?
Next, the State will force us to use battery powered electric generators!
Ssshh.. don't give those science challenged clowns any ideas...
WRT location...
it isn't just the relative location of the two boxes. a lot depends on the particular environ of the equipment. as mentioned earlier a room below lighted with an array of old fluorescent fixtures can have a significant detrimental effect. other sites might be relatively "clean". in other words what works for one builder may not work well for others. YMMV.
same with grounding I expect. which might explain the "mileage" differentials we hear about all the time.
just my two cents.
It's nuts how much time I spent when I started this DIY audio thing trying to track down buzz and hum—only to turn off my LED task light on the bench and witness the blissful silence....Plus my only "audio cabinet" option at the moment is a 1950s fully steel corporate credenza reclaimed office item. Not the best environment... but I've pretty much beat it with careful arrangements of power and signal runs—and keeping ALL DC bricks and computers outside and as far away as possible from anything sensitive....for a turntable though—it's a rock solid piece of supportive mass (marble top we added)—one can jump up and down in front of the deck and nothing happens.
SoCal Edison
900 KwH
$450
Distributed generation and battery is the future my friend. Especially if you have salacious tastes, aka Class A amps 😉
Reactions: Dennis Hui
The old thread is this:
https://www.diyaudio.com/community/threads/njfets-for-source-follower-applications.329131/
Here it seems 2SK209 has a bit more H2 and less H3 than 2SK170.
It is suggested that 2SK209 could be "nicer" to listen to.
It is a argument like this which could make the 2SK209 the preferred to use.
I don't want to build them both......so I need to decide.
I still have time......kit not yet received. It is in the Danish customs. Will soon get a bill to pay to get it released.
I wasn’t able to make a single-box Pearl 3, with a transformer PSU, quiet enough for MC. Now I’ll be the first to admit that my tolerance for hum is essentially zero, when turned all the way up, far, far, past listening levels.
<SNIP>
Two issues to deal with, magnetic and electrical.
You can try orienting the transformer to minimize the magnetic field impinging on the PCB -- and in this regard note that the P3 pcb is much less a "receiving antenna" than the P2 pcb. You can try a different transformer, say an EI vs toroid. You can encapsulate the transformer in a soup-can which is bi-metallic. (A 28 oz tomato can works well, need not be San Marzano!) . You can get a sample kit from muShield, or try the magnetic shielding tape from 3M.
Morrison's book which I cited last week (unlike Harvard, I cite my references) has a lot of detail on reducing magnetic interference, but I don't expect you to go to Ebay to find a copy! Perhaps some duplicative language of Morrison's explanation would be in order.
Electrical is almost always a grounding issue.
I tried to cover the Toroidy transformer as much as possible with Permalloy I think it is called (to my knowledge same as mu-metal).
Toroidy already has magnetic and static shield (according to spec) but I thought it could not harm to do a little more.
Next step would be to attached the umbilical and then assemble it fully. Then I am ready for the P3 kit.
Reactions: Plott and 6L6
