Pearl 3 Burning Amp 2023
To match the J112 I didn't need any special jig, I matched them in circuit. On one PCB I installed socket pins for J112 (pins from IC socket), I insert the J112, measure the voltage accross R27 (220ohms), and select two JFET with the same voltage drop on R27. Most of the JFET I tested from my bag were pretty close to start with. Solder the other JFET on the PCB, left the pins on the first pcb. Easy
Thanks for the listening report, keep 'em coming!
A bit worried about your description of the treble. The diamond tweeters in my B&W's do not need more treble or "forwardness". Also curious if others also find the P2 to be quieter then the P3. Hiss is one area where my P2 could be improved upon (Accuphase phono board has 6dB more gain and less hiss than my P2).
It was the recording. I was running it with the Audio Note AN K/LX. I've also run them with Acoustic Energy AE1 ( aluminum drivers ) and it's an accurate treble. Whereas the P2 is a bit softer. Consequently, the P3 is more accurate and shows blemishes in the recording, whereas the P2 seems to tone it down.
Bottom line is that as built, the P3 has a more extended treble. I have the Burson opamps waiting, but I want to listen more.... this is fun. Now, I need to find my copy of Brothers In Arms.... 24 years ago, after the construction, I put up the LPs back on the shelves but didn't arrange them. I told myself someday I'd do it, but somehow I've always found that it more satisfying to listen than to arrange... except when I want to hear something specific...
I have no issues with hiss in either P2 or P3. Running 55db gain for the Grado 1mV. BTW, my P2 has a lot of good parts with a custom backpanel ( no DIP switching for me)... so maybe it's a Super Randy P2.
These are all very squishy words. ( IMPRECISE )
Too subjective for me.
The words I use are not squishy at all... they are standard audiophile jargon.
At least, you didn't drag me into an ASR like discussion about "fast" bass.
I mean, what do you want?
I hooked up my HP1980B to the output of the P3 set up with an input of 1Mohm..... Ran an HP3325B in a sweep test at 1mVrms with a SissySIT... from 20Hz to 20Khz. The measurement graphs show a +/- 3 db from 17.07Hz to 21.88Khz. With a 1Khz square wave, the rise time was 40Mhz/sec, the slew rate was..... All components were calibrated, instruments were programmed via an HPIB board. Room temp was 20C, sea level, humidity of 50%.
Julian Hirsch and ASR are simply not my forte when it comes to listening to an audio component ( Mind you, I know how to run lab/metrology instruments quite well). But at this state of my life I trust my ears... so if I tell you the bass is EXPLOSIVE, it just means that the macrodynamics are... AWESOME.
Warming the stereo... NOW...
Reactions: SomekPoland
Hello tonyEE
To hopefully keep this fun and on topic You could call me dtME.
I am from the school of thought that I can measure things that I can not hear and not so much the other way around. Then there are times when the test bench is at the other address. You know that time and place thing.
If the playback of the drum set solo lacks dynamic range and impact (pun) the first place that I would look is the power supply. Does the voltage regulator maintain the output voltage or does the output voltage sag on the crescendo.
The ne5532 slew rate is more than fast enough to keep up with audio frequencies.
When the curly redheaded girl next door comes over to visit keep the door to the lab closed.
Thanks dtME
Reactions: tonyEE
Hello tonyEE
Thanks dtME
Pretty much, taking the standard measurements, which today entail frequency AND time domain.... is the baseline.
What we lack is an understanding of why things sound good. We know when things sound terrible... and we can usually measure that. like a lot of the early digital stuff was done in the frequency domain... but when they got around to the time domain they started to see stuff like PRE-RINGING.... ooops... not good.
Similarly, if an amplifier can't deliver the "rated power" then it's likely two things (a) the rated power is optimistic for the design or (b) the amp is faulty/broken.. It could be the FE or output stage are not up to par and/or the power supply is not able to handle the necessary power. Either way this can be easily measured with a function generator, a resistive power load and a voltmeter ( a scope would provide more interesting data ).
But, just as Pass has noticed that negative 2nd harmonic sounds good.... we don't know why. All we know is that if we start with an amp with little harmonic distortion and add just a bit of negative 2nd harmonic the soundstage sounds more realistic. Why? We don't have the cognitive models that explain and predict it. We just know that it just is. I believe Pass did write about this very specific issue.
It's kinda of interesting and I don't know that much has been done in the research. Back in '85 I almost went back to get a PhD studying psychoacoustics in the Physics Dept at Cal State Long Beach... they had a prof doing interesting research into it... including electronic design, etc.... but by then I was making money and it was hard to be poor again.
BTW, if my user name reflected my profession, it would be TonyPhy...... but my username is usually TonyE... when I created the account in here, that username was taken... so my second option was TonyEE. A number of people think it means something different. It was an unfortunate decision but I remember that username ( use it in other places with such issues )...
Anyhow, I still have not been able to get around listening today... too much stuff going on, but the stereo is playing the radio nicely...
I bet you'll enjoy OPA1612 (on SOIC to DIP adapter) and OPA2210 (on SOIC to DIP adapter).
(vendor suggestions)
_
There also exists those adapters which makes two single opamps to a dual dip8.
I have some singles so I acquired some of these adapters. Then I found out that 4898-2 has equally good specs as the 4898-1. Then I just go with the dual type. I am not an "opamp rolling" person. I just want the P3 to be quiet with low distortion.
It's definite: our Pearl 3 sounds better with the OPA2132P than with the OPA1642. That surprised me, because I've used many (ca. 45) of the latter in several preamps in which they sound really nice, and marginally more detailed in those units. Well, shows how circuit design can be affected so much by particular component choices, not to mention how the synergy of phono preamp, line preamp, amplifier, and other items in the chain can vary so much.
The chassis box I had selected was never shipped, so I had to place an order with another seller. Beginning to regret not just buying the ModuShop pair of boxes...
I guess the dedicated P3 chassis two box set is not yet available for purchase from ModuShop?
Yes it is nice not having to worry about paying the rent.
I have one of the Pass H2 pre amp kits here on my bench. I think that I will apply some of the power supply technology from this P3 project to hear any effects of 2nd HD 180 degree phase.
Seems like there is always an ample amount 3rd Harmonic that comes along with the 2nd
Thanks DT
With any op-amp listed you'll have low distorsion... Probably the higher source of distorsion in this design comes from the turntable system playing an actual record...
SB
I have a belt driven Linn LP12 with Lingo, Karousel, Trampolin, Ittok, Grado Master 2.... no distortion!
Now, you guys with direct drives, specially those Technics... well, that's a different story.
Besides, I warm up my turntable and then before getting serious, for five metric minutes I play some special Linn Keltic tunes while I dance ( it helps I'm on a slab, if you're on a suspended floor you should get the Linn Keelare Dancing Platform). This way you get the table heretogenized with the preamp and tuned correctly.
