OLD THREAD DAC End by Andrea Ciuffoli
All circuit DAC-END new up dat
I see no output capacitors. Is it using the local decoupling capacitors on the chips as output capacitors? Integrated regs on board with the chips? Without output capacitors would be very wrong. At least 47uF and enough ESR.
Originally Posted by ben-jam-in View Post
1. pathetic (1 set)
2. cchean ( 2 sets )
3. Lucylu (1 set)
4. Ulyses31 (1 set)
5. damohpi (1 set)
6. mikvous (3 sets)
7. gipione ( 1 set)
8. flocchini (1 6h6P if done, 1 Salas HV)
9. belkoff (full set dac end 2 + 1 6h6P if done, 1 Salas HV) + schematic for each PCB
10. klaju1955 (1 set)
11. ben-jam-in (1 set)
12. morpheous
13. hotzman (2 x full set new dac end 2 pcb)
1. pathetic (1 set)
3. Lucylu (1 set)
4. Ulyses31 (1 set)
5. damohpi (1 set)
6. mikvous (3 sets)
7. gipione ( 1 set)
12. morpheous
14. le´flu (one complete set of new DAC-pcb)
Hi Quanghao, I was the first person on your last board order and I STILL have not receive ANYTHING from you....... Would you kindly send me out another set as I suspect that nothing was ever sent out. I have all the parts waiting so if you could look after this ASAP it would be greatly appreciated.
Thanks STROSEK
me too...
1. pathetic (1 set)
3. Lucylu (1 set)
4. Ulyses31 (1 set)
5. damohpi (1 set)
6. mikvous (3 sets)
7. gipione ( 1 set)
12. morpheous
15. alexmi (one complete set)
not anymore
I'm sorry, I changed my mind...I'll delete my position in #15
thanks, Alex
1. pathetic (1 set)
3. Lucylu (1 set)
4. Ulyses31 (1 set)
5. damohpi (1 set)
6. mikvous (3 sets)
7. gipione ( 1 set)
12. morpheous
me 2
1. pathetic (1 set)
3. Lucylu (1 set)
4. Ulyses31 (1 set)
5. damohpi (1 set)
6. mikvous (3 sets)
7. gipione ( 1 set)
12. morpheous
15. klie (1 set)
1. pathetic (1 set)
3. Lucylu (1 set)
4. Ulyses31 (1 set)
5. damohpi (1 set)
6. mikvous (3 sets)
7. gipione ( 1 set)
12. morpheous
15. klie (1 set)
16. Yomanze (1 set)
I also use 47uF 16V instead of 10V! No problem whit that!
You should give a try here:
Electra-Print.com Audio Transformers
If having a custom transformer made was what was needed I would go with EDCOR Electronics Corporation, they have the best prices I have found in the states....exceptional products as well. I have just have Edcor take care of this for me in the end but for now I would like to see if I can keep the price very low.
Jeff
I went back to Edcor's websire and found exactly what I was looking for: http://edcorusa.com/Products/ShowProduct.aspx?ID=629
I have used edcors transformers before and removed the endbells so I could mount them sideways for a lower profile, this is what I would do here so I could place this inside the chassis. Not a bad price at all, $32!
Jeff
Thanks.
Once I have settled on final touches I will put it in a wood box with copper accents.
For those interested in the 6H6P,6H1P,6H2P I can recommend Oliver's Tube-I-zator board. I had it hooked up to the DAC End2 for a couple of hours this PM and it also has superb sonics. Tight bass, superb voices and excellent detail. Nice option if the NOS ECC182s keep going up.
Enjoy
Hi, what value did you use for Ri/v for the Lampizator board? Thanks.
