Official LYNX Power Amp builder’s thread
I want to replace R128 to R135 by equivalent (in global value and power rating) 0,6W 1% metal film resistor in parallel. So i need to know if the 5w power rating is real necessary. I will apply about +/-35VDc rail power. I choose 0R33 as value for these resistors.
It all depends on no. of output devices and speaker load.
Then it's straight forward using Ohms law........
Taking worst case senario;
Vout: 32VDC
RL: 4Ohm
Re: 0.33Ohm
Vout/(RL+Re)= Iout
Iout x Re= Vre
Vre x Iout= WRe
As you use 4 output devices then result for each Re is WRe/4
Hi, this is my fifth prototype of modified Lynx.
I sent some pictures and schematic of a third prototype to ACD. ACD called it "Baby of LYNX". This name Likes me 🙂 . Baby of Lynx have a power supply with symetrical 40V (only one pair of power transistors).
I measured BoL with AP2722:
Output power:
105W / 4 Ohm
75W / 8 Ohm
THD < 0,004%
SNR (A- weighted) > 120dB
Spectrum of output signal:
http://img125.imageshack.us/img125/6199/spektrumal7.gif
This foto shows only prototype. The final amplifier will be done in February.
Sorry to disturb again about the emitter resistors
When I look at the spec. of the AC05, they measures 7.5mmD x 17mmL. I had a sample (which is probably not an AC05 and it isn't 0R47 ) which measures 9mmD x 19mmL. Does anybody knows anything about it?
The 1st one from the top seems to be a KNP series (24Lx8D)
The 2nd one from the top is the one I am talking about.
The 3rd one from the top would be a 3w KNP
Correct me if I am wrong, tks
Rail voltages
Sorry to interrupt your question, bigpanda.
I'm ready to install and make the first tests on the LYNX. I bought Jan's big toroid which has 42Vac secondaries. When I measure the rail voltages they are 4x61.4Vdc. In the specs and in the assembly guide, Jan has written +/-60V as the maximum.
Am I too far off here to be able to use this trafo? Or are my 61.4V ok for the LYNX?
Thanks for any help.
/Bo
You should avoid the wire wound resistor = inductance
Metal oxide is fine.
