The 500L boards still sound awesome, big improvement on my system. More spacius and detailed, absolut recomended. Only reason for buying the R2 is for bass amp.
Im in love.
Im now running the boards with bias at 70mA for eatch transistor rail. Heatsink temp ca 43 celcius.
Anthony know his work !
Im in love.
Dont know witch type, i suppose someone can answer. Only xlr for my system 🙂
Im taking output devices, the Lateral mosfets he is using:
Exicon Lateral MOSFETS - Our Product Range
800L boards in order 🙂 Volt One and PowerOne3.0.
Building a dual mono stereo amp.
I tried the dualpowersuplly on my 500L boards and its absolutely wort the mo ey in uppgrade with dual supply.
Even better precise soundstage !
Love the Holton amps big time !!!
By dual power supply, you mean to power the input and output stages with different supplies?
Putting togheter a low budget 500R2 dual mono.
Used enclosure, used 500R2 and used toroids from Thule PA200 monoblocks
2 x 500VA 2x45 volt.
12 pc 10000uF 80volt Roe for each channel.
Soft start modules from Jims Audio.
Geofei binding posts.
Neutrik Gold xlr.
Cheap iec w switch and fuse.
Al ac is 2.5kv solid core cooper.
MIT speaker cable.
Neutrik Gold xlr.
MIT speaker cable.
Anyone with experience with placing the toroids upvards ?
Should i use an aluminium plate towards the amp and cap boards ?
Some caps hase arived 🙂
48 pcs Nichicon KW 2200uF 100 volt for each channel.
In first rounde im gona use toroids with 33 volt ac, and high bias. If that doesent work out very good im using toroids with 60 volt ac.
Wow that is a lot of caps😱😀
- Holton Precision Audio
- My Holton amp builds.
