Muses Volume
I've finally soldered all boards (main / controller / volume).
I have a transformer. It has secondary 18-0-18(center-tap not dual), 8-0-8(center-tap not dual).
I've connected the transformer and main board like this ( https://www.diyaudio.com/community/attachments/img_4612-jpg.949600/ ) and heard weird sound (du-du-du-du-du) from the transformer.
Is this connection not possible?
Do I need to purchase a new transformer that has secondary dual 18-0 and single 8-0 ?
Could someone please let me know which header to use to stack the volume attenuator to the main board? I thought I had followed the BOM to the letter, however the pins aren't long enough.
Could someone please explain how I should have the jumper settings for unbalanced using Main board, controller and volume ?
