Muses Volume
Reactions: 1 users
Joined 2019
Very nice.
If you will use massive aluminum volume knob, apply a smidge of Teflon grease at shaft, where it enters encoder, speeding it with rotation and exercising pushbutton action. With a very heavy knob, it could squeak a little after some time.
Reactions: 1 users
Alternatives of BOM (Mouser)
Are these OK?
Mouser #: 667-ERA-6AEB202V <- 667-ERA-6ARB202V
Mouser #: 667-EEU-FR1V221 <- 667-EEU-FR1V221BJ
Mouser #: 625-DF02S-E3 <- 625-EDF1DS-E3/77
Mouser #: 583-SR160-B <- 637-SB160
Mouser #: 595-TPIC2810DG4 <- 595-TPIC2810D
Mouser #: 647-UKL1A470KDDANATD <- 647-UFG1A470MDM
BTW, I cannot find an alternative of omron Relay ( Mouser #: 653-G6K-2P-DC4.5 )
Have you been able to find the Omron relays?
Hey Daniel, got a question regarding the v2 uC and Volume boards:
  • For the uC board the pdf manual says C7 47uF/10V, however there is no C7 marked on the board, only up to C6?
    Actually there is a 2nd C6, it is SMD cap right to the ST processor.
  • For the Volume boards for C1, C2 the pdf manual says 180μF/25V but the Reichelt order number for this position is "RAD FR 220/35", which is 220uF/35V cap. So, is it 180 or 220uF better used?
Thanks!
