MPP
The 450 to 490 group lies within 10%. That is a very low spread. Much easier then matching J-Fets. I would also measure the BC327. I think that is what you will do too.
I would use the ones with the highest Hfe that match NPN-PNP for the input transistors.
That way we get a slightly higher input impedance and less Dc current into the cartridge.
That could be the 510 - 530 group. The middle ground from 450 - 490 can then be equally distributed in the current mirror and the house keeping.
Nice statistics program that you have !
Does anybody know when the BC327/337 have being introduced ? They seem be to around for a long time. The only reliable information i found is that they are recommended over the BC550/560 at higher collector current, say 100mA, where the BC550/560 are not so good any more. The only mentioning of their low noise capability was in a paper by Janacec.
I hope that i spelled his name right.
Strange then is that the BC550/560 are always anywhere preferred for low noise audio although the BC327/337 has lower Rbb´( 30 Ohm instead of 140 Ohm ) , is more complimentary, has a rather flat Hfe curve ( the -40 model can compete with BC550C, 560C in terms of high Hfe also) and has an extremely high early voltage. A little high Cob though, i found values between 8pF ( Diotec ) and 12pF ( Siemens ). But fear not, the Paradise is super fast due to the way we use it.
I´m beginning to understand your sense of humour too 🙂 There is no torment here.
Six Sigma is almost never obtainable in normal processes but we use it as reference against which we measure our systems.
We use DMAIC to try to reach Six Sigma.
Sony contacted Seas a long time ago. If they can make tweeters where only one in a million falls out of spec. They geared up tremendous, spend incredible amounts of money ( for such a small company ) but ultimately they failed. That nearly killed them but know they had a very good quality control system and i gained from it a lot. I just had to spec for example plus-minus 1dB from the reference, and here we go.... No selecting of tweeters any more at Audio Physic.
If you like it or not, here is what I have on the BC327/337. The information is from 1979.
Manufacturers listed are CEN, ELMA, ITT, MULB, NASB, NSC, PHIC, PHIN, RTCF, SIEG, TIID, VALG, NECJ, MOTA, MEHK, NSC, ALGG, FREB and RTCF.
I would say a quite popular little bugger at that time.
Page 188(left) line 40, Page 146(right) line 9
Thanks, so we got more stupid in the meantime...
This could really be the summing cite of the past couple decades, at least for discrete semis... 😀
I think first time I laid my hands on bc337/327 was in late 80's, when I had my first adventures with complementary output amps using "legendary" (in the pejorative sense, because there was almost nothing complement about them) russian KT805/837, as nothing better was available at that time on this side of the wall. BC's for VAS made results some how less disappointing so I used them since, despite all the preference for 560/550 by majority of designs.
Btw, happy coming new year guys :deerman: It's been pleasure to read and post here !
