MOSFET Amplifier IRFP240/IRFP9240
Fan Control with signal from amp outputs...
apexaudio, I corrected your diagram above. It's better that way.
And I don't think the PEAK circuit is calculated or work correctly!!
dear bushulo,
do you have obtain gerber files or pdf of hv350.2 pcb.i live in lucknow by this locotion i came to know that you belong to goa .i recently make a tour for goa,staid at hotel goa international in panji at meer mar beach.by the way it is very pleasant city i am too impressed with this city.my English is poor plz not mention.thanking you.my e mail is alvi.masood251@gmail.com
hello, is it safe to use 2x63V for 3 pairs of IRFP240/9240? This should give about 250W to 4 ohms. There is no problem at 1khz and 10khz, but when we go close to limitation at 100hz in 4 ohms, then all IRFP240 burn. Maybe these transistors are fake?
3pr of 240/9240 adds up to ~900W of output devices.
Divide by 4 for MosFETs and you get ~225.
Your target of 240W into 4r0 is close enough to 225 to be considered as reliable.
However, your target of 240W and +-63Vdc do not seem compatible !
I get 300W to 320W from +-58.5Vdc supply rail using BJT output stages.
A mosFET output stage may require upto 5V more on the supply rails to achieve that 300 to 320 target.
But you are showing a target of "only" 240W from supply rails that are 4.5V higher. That seems odd.
