It seems a shame to have to try different OPS to get this stable. The original design looks good and has been shown to work. There could be some variations between parts - the parasitic capacitances of the tubes (try different tubes ?), sockets, heater wiring, general wiring and speakers and power supplies etc. etc. Maybe one of the compensation caps is 'bad'. I wonder if it isn't worth trying to tweak the compensation of the baseline design a bit more, pull down the OLG at higher frequencies a bit more aggressively. It may not be where you want to go long term but short term it might provide something that is working and can be improved on further. And then you can compare the two OPS for sound rather than introducing another variable into the detective story at this early stage ??
Gareth, it's a good opportunity to investigate the issue and finally make the design "bullet proof". I have ordered the OS's Slewmaster PCBs in order to build it and try to reproduce the exact setup Terry is struggling with (as close as possible). Hopefully, it will oscillate (fun to wish so, huh? 😛). There are still some tricks I did not try yet - one of them is grid stoppers. Simulation shows, together with grid capacitance, they influence the overall phase response above 10MHz. Also, as you suggest - more aggressive killing of OLG at HF may help, but I would better test it myself, instead of waiting for somebody else frying the output devices.
Looking forward to getting the PCBs and finding the exact cause of the problem 😉
Valery
The reason I am trying a "different OPS" is because this was offered in the Slewmaster thread as viable IPS. Were this just offered here as a complete system with Valery's OPS I probably wouldn't be bothering you.
In theory the SlewMaster OPS should be very flexible / compatible with different input sections. I'm curious to learn what is up between Valery's IPS and this OPS.
Hi Terry,
With help from Jason, I am ordering the Slewmonster PCBs, so hope to look at the issue closer pretty soon.
At the same time, if you're up to couple of experiments - not dangerous and "non-invasive" for the boards, here are two options to test:
1) No NFB for OPS (Picture 1). Put two 2.2k resistors, right underneath the board, as shown on the picture. Don't connect NFB plug to OPS.
With no NFB, OPS will not influence stability, so the whole thing should work the same way as there's no OPS connected. Don't forget to re-bias the OP.
THD will increase, though it will still be within 0.05% if biased properly (80-90 mA per output pair).
IF 1-st OPTION WORKS FINE, YOU CAN PROCEED TO THE SECOND ONE.
2) Nested NFB (Picture 2). Change R13 to 100k and arrange another 100k with two 2.2k resistors as shown on the picture. Connect NFB wire to OPS as usual.
This option covers OPS with very light NFB (around 6 db), giving better THD than the previous one, while not jeopardizing stability (at least it should not).
I am running the 2-nd option on my test bench at the moment - no audible difference with the original design.
This may be used as an interim solution until I find the cause of an issue.
Valery
Hi Valery,
I tried the two solutions. The first one worked well. Offset was low at 12mv. I was able to set the output bias. I even played some sinewaves and square waves through it. They looked pretty good. Then I tried the second solution and it looked pretty good. Everything came up pretty good on the lightbulb. I was able to set the bias but the offset was about 66mv. I let it warm up for a while and then I hooked up the scope again and played some sinewaves through it. The sine wave looked pretty thick so I think there was some oscillation. The offset began to grow so I tried to hook up a jumper to short the input but one of the clips slipped off leaving the input open. Instantly, the fuses blew. Measuring, I now have some shorted outputs. Fun stuff. 🙁
We are heading in the right direction I think.
Hi Valery,
Ufff... Terry, sorry about the shorted outputs 🙁
Meanwhile, I did some additional research and simulation. Adding 220 pF cap between Q11, Q16 emitters (set on top of R22, R28 pins) increases phase margin further on. With my OPS it's rock stable, reproducing perfect sine and square waves and sounding delicious.
I attach the final schematic for reference.
Waiting now for Slewmaster PCBs... I actually had it in mind as OPS while designing the front-end, but looks like there's something I don't know about it...
Hi Valery,
As much as I am desiring to learn, this is just too much over my head and I am going to run out of output at this rate. I know you are calling this the final schematic but I have a feeling once you have the OS OPS we will be seeing a new "Final" version.
This seems to work until you feed the OPS NFB into the IPS. Hopefully having the Slewmaster OPS will give you what you need to get to the bottom of this.
Hi Valery,
Oh, yes, let's wait until I reproduce the issue and solve it.
Valery
Hi Valery,
Yes I will wait. I was lucky and only blew one output and got even luckier as it was the first one I pulled. All this trouble had me worried so I hooked up a couple of the other IPS and they worked perfectly so I feel assured that there is just something going on with the way the Low TIM hybrid and the Slewmaster work together. I feel confident you will find the issue. I really do want to hear how this thing sounds.
Blessings, Terry
Blessings, Terry
Hi Terry,
In this schematic, RC combination is responsible for setting the right time constant and though speaker-on delay (68K resistor and 220uF capacitor - within the red box).
Brief calculation shows that 220K and 1000uF will give you some 20-30 seconds delay. Please test practically for exact values.
Valery
Hi Valery,
I swapped out the resistor and cap. When I tried it, it never kicked in. I waited over 5 minutes and the LED just kept flashing. I then switched the the 220K resistor back to the 68K. Now it comes on after about 24 seconds. That feels like a long time but may be what is needed. The Low TIM Hybrid does take a long time to settle. A couple things have me puzzled about this circuit. I used a little 2A adjustable power supply that I have an it takes about 3VDC to trip the protection circuit and that only if you have the - to the ground and + to the speaker out. If you switch that so the - is on the speaker out and the + is on the ground it takes about 7.5VDC to trip it. This is testing with no speaker or amp connected so that may change with a load or input. Does this sound about right?
Thanks, Terry
Hi Terry,
24 seconds look fine.
3VDC to trip the protection is acceptable, 7.5VDC looks pretty high to me, however I think this is a peculiarity of DC "sensor" used in this circuit (2 transistors at the very left of the schematic) - it is less sensitive for negative offset than to the positive one. Not sure we can do something about it without significant changes...
Valery
Valery
Hi Valery,
Yeah, probably not a big deal. 7V won't hurt the speaker. Main thing is to protect them from rail voltage. If it goes to 7V it is probably on it's way to rail anyway and will trip.
Initially, I was hoping to use the DC protection alone but if it kicks in at 7V I will see a pretty good thump. Better to use the 24 second delay so it will be close to 0V before it connects the speakers.
So far, all of the Slewmaster IPS/OPS combinations I have tried only go to about 2v offset if one fuse blows. Hopefully this one will be the same once we get the other issues sorted out.
BTW, the schematic I posted has a typo. It shows 100K on the L in but they are both 10k. It should look like the one attached here.
Blessings, Terry
Blessings, Terry
Tested with SlewMonster
OK. Finished soldering SlewMonster. Got 3 output pairs so far - more transistors to come in a couple of weeks.
Connected everything, switched on, set the bias, and... no problem 😕
No stability issues. 20KHz square wave response is perfect, no sign of ringing. Excellent sound - same great bass, natural mids, airy highs...
SlewMonster is a great power section - it does not actually influence neither frequency, nor phase response, at least within 1MHz (as far as I can see on my analyzer). I use 33 pF caps at pre-drivers and do not use optional 68 pF caps at the drivers.
Terry, let's think what can be different in your setup. Power supply? Wiring? Tubes? Are you sure you connect PD+ and ND- wires correctly? I mean, at my front-end they are "mirrored" relatively to SlewMonster - PD+, being "at the top" on front-end PCB, is placed "at the bottom" on SlewMonster. Another thought - grounding. I have G1 and G2 directly connected with a wire at my prototype. Is it the same at yours?
I experimented with increasing LTP degeneration and adding the grid stoppers (cutting the traces and soldering them right on top of the gap). Also increase the VAS cascode load (decreased R26, R27), slightly decreasing VAS gain and ensuring less dependency on the power section input impedance.
Those changes potentially further improve stability, but there was no problem without them as well. I've tried to run very fast single impulses with high amplitude, fast-front square waves - I've tried everything. Solid performance. Attached schematic is the one I have on a test bench at the moment.
Thimios, did you progress with building your copy of the head-end? It would be interesting to have more "statistics".
Valery
Valery
This is good. It is nice to know the SlewMaster series OPS is a solid performer even with other IPS sections. Many thanks for going to the trouble and expense to test this out Valery.
Jason, thank you for helping with the PCBs. This is a very interesting experiment, and after all, it's good to have another good OPS 😉
BTW, 2-pin Molex plugs, I normally use for connections, fit perfectly there.
I'm not home right now but it's very puzzling that yours works without a hitch. Did you buy chance ever check your IPS against the readings I have on the schematic I posted? I don't know where to go from here.
Yes, puzzling for me as well! I will look closer at the readings...
Maybe you could mark up a schematic with VR and VBE readings so I could have something to compare to. I had hoped that maybe I had the PD, VD reversed. You used all red wires and it is too hard to try to follow them but I just got home and rechecked and the PD is definitely closest to the V+ and ND is closet to the V- so I had it hooked up correctly. Weird thing is that it works fine if I tie the NFB from the IPS to it'self but when I try and tie the NFB from the OPS it looses it. I'm doing that again until I can be certain that the IPS is running where it is supposed to. I'll need those readings from you to do that.
Thanks, Terry
Terry, do you have any spare boards for this front end? I would be curious to see if I get a set working.
I just remembered that I used some adjustable caps in this. I'm going to pull those tomorrow and replace them with some fixed value caps and see it that makes a difference. I'll let you know.
- Low TIM, low distortion hybrid front-end
