I found the genelater of tek AM700 have DAC+bandpass filter. The service manual with schematic are available. Check it!
Thanks a lot.
AM700 Service Manual | Tektronix
" Residual THD+N with the bandpass filter in place. These
specifications are baseline for sine waves generated in
the low-distortion mode.
Amplitudes less than –16 dBu are noise limited (22 kHz BW).
Load resistance ≥ 600 Over 22 kHz BW Over 80 kHz BW
100 Hz to 749 Hz
Amplitudes ≥+4 dBu to ≤+26 dBu
Typ. ≤0.001%
(–100 dB) "
Interestingly, this was designed by the same guys that later founded Audio Precision. They learned a lot!
Jan
Jan
Well, thd level is not impressive, if considered w/o freq. spec.:" Residual THD+N with the bandpass filter in place. These
100 Hz to 749 Hz
Typ. ≤0.001%
(–100 dB) "
Sine Wave Frequency Range
High Resolution Mode 10 Hz to 20 kHz
High Bandwidth Mode 11.719 Hz to 79992.188 kHz
Sine Wave Frequency Resolution
High Resolution Mode 0.1 Hz
Conceptually. The details are for the bug guys. The specialists.
-Richard
Thank you for reminding me.
Should be a way to auto-zero-null-subtract and not have to manually tune for a minimum.
THx-RNMarsh
That sounds like a good idea, and I would think quite do-able, but I never gave it any thought at the time. The auto null would probably work something like that in a THD analyzer. Just thinking off the top of my head, those circuits often want to have a quadrature version of the test signal available. That might require some more thought 🙂.
Bob
Bob
Hope you/others can help on this. It would take a good idea and make it into a really nice polished project.
THx-RNMarsh
Following a couple of years of posting from anybody gives you a pretty accurate picture of how smart and experienced they are. Or not.
Jan
I still hope to come across as the swiss army knife of the bug world, do I?
Got it - thanks
(Low noise amplifier strangely on page 862 🙂 )
Paul, Swiss army knives are highly overrated ;-)
Jan
. . . But indispensable in times of need 😉
Rules breaking posts and their collateral have been deleted, however be assured that this is not the end of the matter.
THx-RNMarsh
Does this give any ideas ref to auto-tuning for null with THD meter;
Proposed auto-tuning circuit, (a) architecture of the tuning scheme.... | Download Scientific Diagram
Design of 4-pole filter with auto-zero op amps | Download Scientific Diagram
null detector circuit - Google Search
THx-RNMarsh
Unfortunately the only relevant reference is the auto-null for the HP. This problem is similar but not the same. The other references are not that helpful.
Because this deals with both phase and amplitude you do need a sine/cosine decoder to even know which parameter to adjust. You could lift the circuit from the HP 339A or even the 333/334. Probably would need some manual range controls. Or a raspberry PI and some software.
Demian, I shamelessly lifted the quadrature detector from Bob Cordell's 1984 THD analyzer article, and use that in my tracking notch. Works like a charm. I guess you have the documentation for that.
Jan
Jan
Many of the circuits are just there for spurring new ideas.
The HP339A is an exact app. which could be lifted and mod values to fit the Cordell values. The LDR would be a challenge to find??
The 339A can be copied as well.... with simple changes... the internal osc can be easily improved and the analyzer part as welll without changing circuitry/topology. Or just use the analyzer portion only;
stock and mod;
Not SOTA but easy to do for THD+N meter (-120dbv.... better with a Victor osc)
THx-RNMarsh
- Design & Build
- Equipment & Tools
- Low-distortion Audio-range Oscillator
