Low-distortion Audio-range Oscillator
A few years ago, I did many mods and tests to several THD instruments. The best I found is the ShibaSoku 725 "D" model. accurate to a fraction of a db down to -160dBv. A true laboratory standard instrument.
In so testing, i used Victors and highly modified KH and Davada's and ShibaSoku's generator and others. Including AP 2722.
Right now it is the generator which limits me.... measuring into the -140's.
JD -- the tracking notch is a great asset. Combined with Davada's variable freq gen makes a nice variable freq T & M system for Ultra low distortion studies. .
THx-RNMarsh
Does DiAna stay locked on this drifting signal?
Cheers, E.
I just did a quick test with my Victor oscillator cold. 50 X 128 during the biggest drift. No signs of issues with it tracking. This is with the Lynx.
Different install for Windows. The other one crashed. I'll know if this survives the latest update soon.
One thing to keep in mind is that if the FFT is too long, the bands become too narrow relative to the inherent frequency error and frequency stability of the oscillator. So, over the averaging period, spurious energy could 'float' into several bands and become mischaracterized, since some of the energy of a harmonic will get counted in more than one FFT bin.
Each bin also has a 'response curve' due to the windowing function used. So, if spurious energy happens to fall between two bands, it can be read inaccurately, since energy will be spread among two bins and not one.
The reason I mention this is that I find that with the APx 555, I use a 192kHz analyzer sample rate with 256k point FFTs, and synchronous averaging of 128 FFTs with the Dolph-Chebyshev 250 window. This seems to provide the best tradeoff of bin width, averaging noise reduction and bin top flatness. FFTs wider than 512K seem to make the bins too narrow to get an accurate spur reading. Of course, your AP and these oscillators are different, but it's worth trading off FFT length and # of averages and seeing where you get the most stable and repeatable readings. Also, synchronous averaging is extremely valuable in reducing the noise floor and thus the accuracy of spurious level readings.
Thanks Monte, that's a good point. The max FFT sample rate of my AP is 32k, but I can set the # of samples up to 4M, which is what I used. There is a small improvement when going from say 64k samples to 4M but probably not enough to warrant waiting 20 minutes for the results.
I will try with more averages, that's faster than more samples. I can use synchronous sampling when the AP is the source but not with the Viktor, of course. That may also explain some of the difference.
BTW I used the Flat Top window.
Jan
I might hazard a guess that Victor's oscillator has more phase noise than the AP, perhaps due to noise injected by the oscillator agc. If one runs the agc control JFET with very low signal across it, it will generate less distortion.
However, the penalty is that the agc circuit may inject more noise into the oscillator loop if the agc is to still have adequate control range (authority) for control of oscillator amplitude. This can manifest itself as the notch depth at the fundamental frequency not being as deep, as there are noise sidebands about the fundamental.
Just speculation ...
Bob
Bob, I tend to take your speculations serious 😉
Jan
Anyway for to measure very low harmonic levels, the oscillator board must be placed in a closed metal case without a random air flow from the outside and warmed up within at least 20 minutes.
In my distortion compensator I fortunately do not have to fight stable frequency (same clock for DAC and ADC), but stable level for calibration is important. It takes the soundcard (a plastic enclosure sprayed inside with conductive paint) about 20 minutes to warm up to stable output. My table is next to window and it makes a difference if the window is covered with curtain in the evening - just like your random air flow experience.
Also the capacitor in the LPF discriminator takes about 10 minutes to charge up (or warm up?) until the LPF output level stabilizes down to 0.001dB/minute. Then the capacitor is quite stable even if disconnected from the signal for a while.
One thing I haven't tried yet.
Normally, with the AP2722, the FFT bandpass tracks the generator or the sweep frequency (with the sweep driving the generator).
But for external sources there is also the option to have the FFT track the external source frequency by setting the bandpass to 'Counter tuned'. I'll see if that makes a difference.
Jan
Markus which PCBs? You man the tracking notch? That's not finalized yet, I hope to be able to wring a few more dB out of it.
Also the comments given so far give me some more ideas ... ;-)
Jan
Yes, some features I would like to have/see 😀
- balanced operation (may 2 circuits of them) & none balanced mode
- target tracking notch frequency range 0.1kHz .. 20kHz ??
- Switch to shorting the notch for base signal calibration purpose
(shorting and not a relays switching, while the relay contributes with THD)
- signal operation range 0.1V..10V ??
- providing noise & THD figures of the tracking notch
- notch Q without 2. Harmonic attenuation's
while currently have a 1kHz balanced bootstrapped T-Notch with high noise contribution, while using 10nF & 16k resistors.
Attn Victor:
Additional the victor may improved using lower resistor values but may increase THD's. The deal may is to lower the resistors (may half) and double the cap's and using single opamp's of a dual, due the opamp chip cross talk.
my 2 cents
Hp
Hp
Well, that's not going to happen - at least not from me.
Currently the notch tracks 1kHz +/-5Hz. The tracking input must be very non-intruding so as not to introduce distortion. It is the exact same reason why Viktor's oscillator can not be tuned over a wide band.
Shorting and balanced operation is possible, and operating range is limited by noise at the bottom and distortion at the top. But there's always my Autoranger ;-)
For balanced operation I would propose an balanced input and a single-ended output.
BTW, I was just offered a Keysight Technologies N5225A Network/Spectrum analyzer, for less than half price! Only $ 135,000. Jeez.
Jan
Well, the point for full balanced operation..
OK, may needs 2 of them while even good "sound cards" have only a balanced input as Lynx L22, RME ADI 2 Pro. Otherwise in none balanced mode, we deal also with hum contribution to the hole setup.
my 2 cents
Hp
Don't forget you are now operating at about -100dB and balanced will not have such an impact if any. Having two identical notches in parallel is another can of worms I think. But I will think about it.
The graphs I posted yesterday are se in to se out. BNC, no RCA, no ground loops due to SilentSwitchers ;-)
Jan
Does the second line need to be notched too? How about notching just the hot line and connecting the cold line directly to DUT's output ground (fake unbalanced -> balanced connection)? IME it helps notably with suppressing the measurement ground loop noise of an unbalanced DUT.
Even fetching the ground to another unbalanced ADC channel and subtracting the two channels in software (poor man's fake balanced input) helps Virtual balanced in/out from regular soundcard in linux - results but gentlemen in this thread are not poor and have proper balanced inputs.
