Long skinny builders thread
It is easier with a source-follower as output stage. A single ended output stage with gain makes it more complicated also to control the distortion.
An interesting amp. When the J2 schematic is official released we will see how much of a clone we have.....
I will probably use 2SK3497 as current source for the output stage so it will not be 100% anyway…….and mono blocks…..and RCA input only. Think I will "strap" it for RCA only on PCB.
My build is running
I got my Long and Skinny J2 Clone build working today. My boards are from the recent North America group buy.
I used the 400mm 4U Dissipante chassis and added a horizontal angle to each channel's heatsink.
With a 400VA Antek transformer it runs about 22.1 VDC rails.
Bias is settling in at about 1.425 Amps. Very easy to establish and hold offset at 0-1 mA.
I used 30 watt Caddock resistors as they can be secured with 3mm machine screws and have adequate lead length to mount as shown.
Using Keratherm pads for the Semisouth Jfets, in my shop with 19 degree Centigrade ambient temps, the Jfets are running about 53 degree C, nearby heatsink is 47 degrees and fins are at about 39 degrees.
So far, so good, I hope to get it into my system this weekend for some listening tests....
Thanks to all involved in getting these boards developed and available to us plebians.
Matt
Matt
@JT
I just do standard wiring per Pass Labs / FirstWatt
RCA signal to pin 2 on xlr
RCA ground to pin 1 / chassis ground on xlr
When using the rca input, I use Cardas CGSP shorting plugs in the xlr from pin 3 (- negative input) to pin 1 (ground).
Matt
how can we lower or higher bias
It's not meant to be changed in the J2.
However, if you'd like to experiment, the bias is controlled by the source resistors. Just keep them in the same ratio (roughly 2:3).
I read somewhere, if you lowering value ofR4 15K, bias current goes higher.
My freshly rebuilt J2 is warming up at the moment, with stock parts, bias current is 1.45A, offset is under 1mV.
Thanks to Papa and Jeff! 😀
I read somewhere, if you lowering value of R4 15K, bias current goes higher.
Lowering R4 will increase the bias contribution of the current source, increasing the push-pull flavour a bit and decreasing the singled-ended flavour.
You can also adjust the flavours by modifying the ratio of the source resistors. If the total resistance stays the same then the bias will be the same.
Conversely, if you adjust the total resistance but leave the ratio the same the bias will change but the flavour will be the same.
Or at least that's my understanding of it.
Sweet! :cheers:
